Results 1 to 15 of 25
Thread: 200x cam replacement problems
    Jan 2017
    Bozeman Mt
    46
    Tore into my 200x I bought recently to put a xr200 cam into it. I have the motor on top dead center, the valve tappets are super loose and the cam chain sprocket is removed but the camshaft will not pull out from the head. Does it mean my cam journals are shot? There any fix for that or does it mean a new head? Followed everything in the manual so I'm assuming the cam not coming out freely is a bad sign.
    Jan 2017
    Bozeman Mt
    46
    Also if this makes a difference the cam will spin easily till the lobes try to lift the valves and also there is a little wiggle in and out to it, however it wont slide all the way out.
    The Open Road
    4,727
    There should be a retainer plate you have to remove to pull the camshaft out
    You have to pull the cam and actually measure the lobes in order to know for sure if it's bad. The movement you speak of is normal even with a new cam
    Looks like #7 in this schematic...
    Jan 2017
    Bozeman Mt
    46
    Thanks Ironchop as the manual I have does not mention the retainer. However I removed the retainer and still no luck. Cam only wiggles some and will not come out.
    The Open Road
    4,727
    Quote Originally Posted by deathwobble View Post
    It's kind of a tricky thing to remove for sure. You almost need three hands unless you pull the valve cover (which has no gasket so it can be reinstalled easily with just some new gasket sealer). You might loosen the valve cover, take the inspection caps over the valve springs off, and back off the studs on the rockers that contact the valve stem tops. You also have to hold down the rockers to the valve stem tops so the rockers don't fall between the lobes and keep the cam from coming out
    The Open Road
    4,727
    Matter of fact, just pull the valve cover off the head and you can see the journals and remove cam easily
    The Open Road
    4,727
    When the cam lobes get really worn bad, they get ridges on the side of the lobes and if someone kept adjusting the valve lash, theoretically, those ridges could keep cam from coming out easily
    6,798
    Part number 2 inner cam bushing has most likely gotten groves worn into it as with the cam .
    This will cause the cam to be hard to remove .
    Do like Doug has suggested , pull the valve cover and it will come out easily .
    I have seen this a lot with motors run low on oil .
    Jan 2017
    Bozeman Mt
    46
    Thanks guys, I'll try just removing the head then, might be tricky cause one of the allen bolts looks pretty stripped from someone being in there before. Might have to get tricky with the welder and put a nut head on it or something if its completely stripped. Let you know how it goes when I have time to pull the head.
    Scootertrash's Avatar
    In the sticks
    4,638
    This. As a bonus, it never hurts to freshen up your sealing compounds. Don't use Permatex. Use YamaBond, HondaBond, ThreeBond 1194.
    Jan 2017
    Bozeman Mt
    46
    Thanks. I'm going the pull the head route but one of those allen bolts holding the head on is stripped and on there what seems to me to be to tight. So I bought a torx bit that I'm going to weld into the allen head to get the bolt out. I know with cars you are suppose to disconnect the battery before welding on them, is it crucial to disconnect anything before welding it?
    6,798
    Can’t you get a pair of vice grips on the Allen head bolt to loosen it ?
    A little heat from a torch for about 30 seconds and the vice grips and you should be able to get it loose .
    If your going the welding route remove the carburetor and any electrical that’s close .
    Jan 2017
    Bozeman Mt
    46
    I'll try grabbing it with vise grips just think the bolt is in there tight(probably too tight) so not sure it will happen.
    Jan 2017
    Bozeman Mt
    46
    Alright guys, 2 of those allens were stripped and on there super tight, slotted them and used one of those manual impacts you hit with a to get them out. Anyway today I finally got the head "pulled". Is there anyway to get the head completely off while the motor is still in the bike? cause mine lifts up and gets close but doesnt come out. Also once I had the head pulled I found out that the cam bushing (part #2 in iron chops diagram) will spin on the cam and slide back and forth a bit however the bushing will not slide off, this is why the cam would not pull out with the head on. The cam bushing also has some discoloration from getting hot on one side (blue/purple from heat) does this mean I need a cam bushing as well or why wont it pull off the cam.
    6,798
    Reread my post #8 I explained why the bushing is stuck .
    You will need a new cam and bushing .
    No the head will not come off without removing the motor .
