Results 1 to 15 of 18
Thread: Refurbishing my 85 250r Bassani
    Carthage NY 250r rules
    2,355
    I started cleaning the surface rust off my Bassani head pipe.I want to get back to raw metal look.Click image for larger version.
ID:	251130 Click image for larger version.
    250r rules
    Buffalo, NY
    1,996
    Looks great!
    2,355
    I watched a video on how to blue a pipe so it looks like a custom built pipe.Click image for larger version.
    250r rules
    Buffalo, NY
    1,996
    Only $125 more on the Bills Pipes website.
    http://billspipes.com/index.php?rout...ormation_id=18
    2,355
    I paid $50 for this pipe last year.Guy thought it was a stock pipe because it has heat shield mounts.Those Bills pipes are sweet I watched How its Made episode on Bills pipe.Its on youtube.
    250r rules
    2,355
    I cut out a template for the heat shield.I have some heavy sheet aluminum with holes in it for a heat shield.Im going to trim the template some more.Click image for larger version.
    250r rules
    2,355
    I got alot more rust off the pipe today.I used toilet bowl cleaner the thick type.The front section will need alot more work .The rest is coming along nicely. Another before pic .Click image for larger version.
ID:	251145 Click image for larger version.
ID:	251146 Click image for larger version.
ID:	251147 Click image for larger version.
    250r rules
    TexFest's Avatar
    TexFest is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    U.S.
    339
    this might help
    TPC 450R
    2,355
    This is the video I watched.Thanks for posting it. I have a new phone and haven't figured out how to post youtube videos with it yet.
    250r rules
    2,355
    After 2 more cleanings with toilet bowl rust remover some scrubbing with scotchbrite rust is gone.I wet sanded first with water then with WD 40.and a round with wire wheel looks alot better.Click image for larger version.
ID:	251173 Click image for larger version.
ID:	251174Click image for larger version.
    250r rules
    2,355
    I got a rough cutout of my heat shield .Im going to add a few more cooling holes.
    250r rules
    Sep 2014
    Oregon
    591
    Good post. I was gonna do one for my stock 250r pipe, but haven’t got around to do it yet.
    Trikes owned:
    83 Honda 200x "Liquid X"
    81 DG 250r : Sold
    2,355
    First test fit of the heat shield. Looks pretty good I hit it quick with a wire wheel. Needs some more work and holes.Click image for larger version.
ID:	251321Click image for larger version.
    250r rules
    2,355
    I got the mounting and extra holes in the heat shield. Needs more filing on the edges.I need to get a new torch and high temp clearcoat for the blueing.Click image for larger version.
ID:	251368Click image for larger version.
    250r rules
    2,355
    My first attempt at blueing. Iused a map gas torch I think it was to hot and tip was to wide.Next time I will use a propane torch. Click image for larger version.
ID:	251372Click image for larger version.
    250r rules
