Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: Trx 70 won't run well with choke off
    The Open Road
    4,736
    Quote Originally Posted by oldoo View Post
    Ok great. Thanks for the advice I'll try that.
    Also the needle shows signs of wear/rub marks so an oem needle kit looks like Its on the cards
    That's natural. The needle is a little loose in the slide so it contacts that emulsion tube it goes down inside to the needle jet below sometimes. If it's not deeply scratched, it should be ok.
    Needle getting bent or the end dinged is why they usually get changed out or if you're picky about your fuel curve and a master carb tuner.
    oldoo's Avatar
    oldoo is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2017
    Australia
    155
    Ok cool. I got a nos needle jet kit but will only use it when absolutely necessary.
    For those following. New jets have been ordered from partzilla and hopefully arrive in Aus this week. Will keep you all posted, fingers crossed the new jets get the old girl running as she should.
    oldoo's Avatar
    May 2017
    Australia
    155
    So guys, I installed new jets.... still no luck. I'm leaning towards an air leak? Tried to diagnose it by spraying wd40 listening for a change in sound but no change in engine not I could detect.
    oldoo's Avatar
    May 2017
    Australia
    155
    Update, I found an air leak in the boot that connects carb to air cleaner. On the air cleaner side. Will be ordering a reproduction boot from spanglers and hopefully that fixes it.
    6,818
    That’s why I asked my question in post number 3 .
    The air box needs to be 100% sealed or they run like your description .
    Tomcall's Avatar
    Tomcall is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2010
    Arizona
    215
    are you running with the original stock air box or an aftermarket air cleaner? Curious as I am having issues myself ever since I installed the hotter cam from dratv.
    oldoo's Avatar
    May 2017
    Australia
    155
    Quote Originally Posted by Tomcall View Post
    Yeah oem airbox and brand new filter. I am yet to fix the air leak as I have been busy attacking the rear end. I'm sorry but I don't have much experience with the hot cams in these motors so can't really help you.
