Clutch Help
I took apart the left side of the case on a YTM 225 DX in order to fix the starting issue it had. After it was all back together I noticed it was not going into gear when I would shift it. Would this be due to it is a wet clutch and there is no oil in it yet or could I have messed something up? Reason I ask is if I probably messed something up I don’t want to put oil back into it until I check it out. Thanks.
Try rolling the trike when you shift it. Helps if the shafts are moving.
It sucks to get old
//ArrowChat Integreation Code
