Results 1 to 8 of 8
Thread: Honda 200X questions
    MotorCity is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2007
    Detroit
    195
    I"m trying to find out some info on Honda 200X.
    1). Is there much of a difference between 1983 model year, compared to a 1984, and 1985 model year? Pro/cons of any (reason I ask, I'm looking at a 83 model year, but wondering if there is anything to worry about on a '83, versus a 84 or 85 model year.....I'm familiar with the Honda XR dirt bike series, and there were big differences on these...just wondering if the same is true on the 3 wheelers).
    2). Anything to keep on eye on for these models? any known failure items to be concerned wiht? Parts availability?
    any and all info appreciated.
    Thanks.
    6,804
    The kick starter internal gears are real weak on the 83 model .
    The CDI was also changed in 84/85 because the 83 would backfire and kick back while kick starting / breaking gears and harder to start .
    The tubular swingarm on the 83 model tend to crack .
    Aug 2007
    Detroit
    195
    thanks Shortline. exactly the type of feedback I'm looking for.
    Arizona
    843
    I have an 83 200X. I never had a problem with kickback. In fact, it is one of my easiest machines to start. It does have a tubular swingarm, but I've never had a problem with cracks. My kicker works fine too, but I have heard of problems with the internal gears wearing out. If you find a good deal on an 83, I wouldn't avoid getting it just because it is an 83.
    6,804
    You probably don’t have the original CDI box then or it was changed during the factory recall .
    I do agree if it’s a clean machine I wouldn’t hesitate to buy it .
    Quote Originally Posted by christph View Post
    May 2016
    OH Canada
    1,102
    The '83 was more mass produced compaired to the rest of the 200X. Good supply of parts are still available.
    Things to look for:
    clean tank
    brakes both work. Known for master cylinders siezed up
    burns oil. Smokes
    rear bearings. Play
    '83 200X
    Aug 2007
    Detroit
    195
    thanks again all. really appreciate the input.
    Mar 2017
    Chico CA
    119
    Make sure it shifts through all of the gears nicely and ride it around shifting from 2-3-4-3-2-3 etc. They are known to have issues with 3rd gear.
