Results 1 to 7 of 7
Thread: Clutch change - how hard?
    renotrikeguy's Avatar
    renotrikeguy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Reno,Nevada
    433
    Well I think it's time to change the clutch in my 250r. I pull the clutch in and shift into first gear, and the bike starts moving at a good pace.
    My question is how hard is it to change the old one out and put the new one in? The price doesn't look to bad either... Is this something a newcomer can do or should I leave it to the pro's ??
    Chris (Reno,Nevada.)
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    85 Honda 250es BigRed
    99 Honda XR250R
    04 Honda CRF150F - Cousins Ride
    Michigan
    1,220
    Easy, if you can remove the cover you can more than likely change the clutches. Pull them out and remember what came out first and last and you will not have a problem. I usually pull the whole pack out and lay it in front of me in one piece and put the new ones in the same order.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,244
    i did a clutch change in my wifes 250r night before last. i managed to save the case gasket and it was done in 1.5 hrs easy with a new waterpump seal, if your in there change that seal so you don't have to go back in later,,,,,,
    Michigan
    1,220
    :shock:
    Water pump seal in a 81 250R? Good luck finding that one. Sorry CASEY, couldn't resist.
    Reno,Nevada
    433
    Thanks for all the input,
    Guess I will have to check the cable first in the morning. I just priced the clutch plates over on ServiceHonda and I just hope they arent discontinued.
    Is there a such thing as a universal clutch cable ?
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    99 Honda XR250R
    Ithaca, NY
    2,596
    the clutch plates are not cheap, mabey $35 bucks, it takes mabey 30 minutes or less to change an air coolers clutch. Its designed really well, the clutch cover uses an o-ring, so no gasket scraping, no sealant, no problem, Its gravy. just drain your trans oil first! You can get vesrah clutch plates from anywhere, I usually buy stuff like that from Dennis Kirk. also, they would have a clutch cable. Stay AWAY from OEM anything that is a consumable type regular maintenance part.
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    Reno,Nevada
    433
    Thanks to all that replied to this post. I double checked a few things and it was just like John - jeswinehart thought. My 22 year old clutch cable had stretched over the many long years.
    This is in my opinion the best site for information and advice on these 3 wheel wonders we all love to ride..
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    99 Honda XR250R
