This is the first 2 stroke I've owned in over 15 years so I'm not too keen on all the clatter these things make. Even though that's the case, it still seems like this thing is making more racket than it should. It's a rattle that happens cold or warm, idle or high rpm, all of the time basically.
I pulled the engine out and removed both side covers. The only thing I can see is that there is a bit of side to side wobble motion in the kicker gear on the shaft. Like there's too much clearance between the gear and shaft. It has also rubbed a bit on the rib inside the clutch cover.
Already know I need to do something about the kicker since every once in a while it doesn't engage. From the little I've read, this is a common problem on '85s...
Either way, is it possible I'm getting the rattle from the wobble in the kicker gear? Something else I should be looking at?
