Results 1 to 10 of 10
Thread: Carb Question Hurry!!!
    Ok I need a response fast, is a pilot jes supposed to have a hole straight through??? The jet next to the main one.........On one end it has small holes in the sides of the tip but are you supposed to be able to see light through it????
    O yea I'm trying to tunnel trgouh it with a pin and it won't go that's why I ask
    Ashland City, TN
    2,576
    Yes, it's a small hole all the way through. A pin may be too big to get through though, so blow it out with compressed air.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    nitekrawler is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2003
    430
    Quote Originally Posted by SSJ3Goku
    He is right 8)
    1982 Honda Atc 250r - Daughter's
    1982 Honda Atc 250r - Son's
    http://forums.atvconnection.com/photos.cfm/ID/1566/#TOP
    Jul 2003
    430
    Need jets go here
    http://www.rageperformance.com/carburetorparts.asp
    Rittman, Ohio
    6,276
    Re: Carb Question Hurry!!!
    Quote Originally Posted by RyanRX7
    Its the other way around. The main jet is the jet with one hole through it. The longer one that looks like a spaghetti strainer on the end is the pilot jet.
    Jul 2003
    430
    Quote Originally Posted by TimSr
    OPPS :!: He is right, 110%
    Yes the main jet is in the middle, next to it is the pilot jet and the adjustment screw is next to that. There is a nice clear hole in the min jet, the pilot (which is for idle RPM fuel delivery, which happens to be why I'm working on the carb in the first place) I can fit a pin in both ends just fine ( about 1/8 into the jet) but not all the way through.
    Jul 2003
    430
    I have one, what size you need? I have one for my 250r 82 Atc
    I have a 50 pilot and 148 main jet available :-D Let me know
    welp problem solved, SSJ3Goku was correct. It did have a hole all the way through, and a pin was too large. I ended up clearing it out with the wire inside a twist tie. This solved my problem if any of you had read my other post about my trike nor wanting to idle. The pilot jet was seriously clogged keeping fuel from being delivered at low RPM. Can't wait to test her out tomorrow. Only one question left, what was that (starter jet) so damn had to move when i reinstalled it??? It stuck in for a while, it was a very tight fit.
