Have a 84 Honda 200m, what should I do to it as in parts/mods![]()
Does it run? If so what do you want it to do for you. There are plenty of mods for that engine but that particular trike isn't going to treat you well anywhere if your going fast.
1985 ATC125M: Parts
1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
1988 TRX250X
1983 ATC200E: Total Pile.
"Bout Tree Fiddy" Master of Thy 22RE
Ride it.
Maybe repaint it.
I was planning on just using it to ride to fishing spots and such but I wanted to do some basic performance mods and stuff and things that make it funner to ride. I wanted more power out of it to go through more mud holes and maybe a little faster even if I ain’t gonna race with it.
83-85 ATC200X cams will work in that topend I believe. You can also get higher compression pistons for it as well which will help alot
http://www.webcamshafts.com/mobile/a...)_sohc_2v.html
Or Megacycle...download the catalog and got to the 83-85 ATC200X page
http://www.megacyclecams.com/
K thanks that’ll help but more help is greatly appreciated. I’m thinking of going to the local salvage yard and grabbing the cam, rockers, and piston off 200x?
