Results 1 to 6 of 6
Thread: What should I do with this thing
    Dec 2017
    Michigan
    8
    Have a 84 Honda 200m, what should I do to it as in parts/modsClick image for larger version.
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    Does it run? If so what do you want it to do for you. There are plenty of mods for that engine but that particular trike isn't going to treat you well anywhere if your going fast.
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    The Open Road
    4,736
    Ride it.
    Maybe repaint it.
    Dec 2017
    Michigan
    8
    I was planning on just using it to ride to fishing spots and such but I wanted to do some basic performance mods and stuff and things that make it funner to ride. I wanted more power out of it to go through more mud holes and maybe a little faster even if I ain’t gonna race with it.
    The Open Road
    4,736
    83-85 ATC200X cams will work in that topend I believe. You can also get higher compression pistons for it as well which will help alot
    http://www.webcamshafts.com/mobile/a...)_sohc_2v.html
    Or Megacycle...download the catalog and got to the 83-85 ATC200X page
    http://www.megacyclecams.com/
    Dec 2017
    Michigan
    8
    K thanks that’ll help but more help is greatly appreciated. I’m thinking of going to the local salvage yard and grabbing the cam, rockers, and piston off 200x?
