Page 11 of 17 FirstFirst ... 9 10 11 12 13 ... LastLast
Results 151 to 165 of 248
Thread: KTM Three Wheeler Conversion - Done!!!
  1. #151
    Mexico
    9,018
    Today was chain guide day. Started with a nice simple design, but then it occurred to me that the gearing might have to be changed. The guide is from a Tri-Z.
    So this was revision two. Has three positions.
    Tacked it on, but I need to route the chain through it before I weld.
    It sucks to get old
  2. #152
    3Z with Fangs! is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2018
    Virginia
    184
    Looks phenomenal, Nico! I'm a fan sir!
  3. #153
    Williamstown PA
    5,825
    Hope that guide lasts. I busted a new own banshee one I. Half 15 miles into a ride. Sproket guards after that on everything.
  4. #154
    Mexico
    9,018
    Sand only, not expecting to bounce it off any rocks.
    The beginnings of an air intake.
    The stepped rad hose is off a John Deere. May need a JD decal for the fenders.
    It sucks to get old
  5. #155
    Soutwestern PA
    2,040
    Which means it will eventually leak. Just kidding, well.... sorta.
    Great work so far. I always look forward to the build updates.
  6. #156
    Mar 2013
    Baldwin, Wi
    603
    http://siliconeintakes.com/ If you want something a bit more classy. Fantastic build buddy!!!!!
    85 Tri-z Basket Case
  7. #157
    Mexico
    9,018
    Check this guys 450 out https://www.yooying.com/220trikes
    I like to be able to see how he dealt with a couple issues I have pending. I see his rear fenders are set back about 2" more than mine and that he added some plastic between the fenders and the tank. I think it looks great.
    It sucks to get old
  8. #158
    Carthage NY 250r rules
    2,355
    Theres pics of this on facebook. BVC built it.They also built an Alta electric conversion.
    250r rules
  9. #159
    N.E. Ohio
    2,002
    There is a Company from the Great White North BRC Racing making a bolt in 5hundy 2stroke.
    Electric, Conterbalanced, Power-valved drops in certain year frames of current used 2stroke KTM's.
    When I saw the conversion and test ride...Made me think a Orange Hybrid would be an awesome trike.
    Like the progress, got the eyes on this one, thanks for sharing.
  10. #160
    Seems like Massachusetts is pumping out some sweet trikes!!
  11. #161
    Mexico
    9,018
    Got the swinger back Saturday and installed all the bearings. Pivotbolt went through both side with one finger push. Pretty thrilled about that considering how much torch and rag work was needed after final welding.
  12. #162
    Las Vegas, NV.
    2,531
    Looking good!
  13. #163
    May 2018
    Virginia
    184
    Always amazing work, Nico!
  14. #164
    Mexico
    9,018
    Thanks guys, I bolted the swinger on for real today, pics when my phone charges,
    Quote Originally Posted by Tri-Z 250 View Post
    Did any of you visit this site Tri-Z posted? This company is converting 300cc KTM two strokes into 500cc torque monsters among other things. Very high end stuff.
    It sucks to get old
  15. #165
    Mexico
    9,018
    Bolted the swing-arm on and then the shock with no spring to check clearances through the stroke. Look like everything clears by a whisker, but I think if I lower the rear anymore the shock reservoir will rub the air box. No matter, it needs to be raised from where it is now by about 1 to 1.5 inches, but I’ll wait till the forks are lowered before making any adjustments.
    Rough measurements show 10” of ground clearance and a 32” seat height. About 1” higher than my Tri-Z seat and 1/2” less ground clearance. Wheel base is 58” and the width is 48.5” at the moment.
    It sucks to get old
