My 250r project I've been working on is missing the rear brake caliper assembly. Is there any other calipers that will work on this trike? Slight modifications are fine! I'm running out of ideas. Thanks in advance guys!
I saw the one on ebay but I was trying to save a little money. Was hoping someone knew if another caliper would bolt on and work with a little bit of work.
Post #7.....
https://r.tapatalk.com/shareLink?url...5&share_type=t
After reading that one above, read this one for newer dirt bike calipers that interchange with that stuff if you want to go that route...
Thank you ironchop! Tons of good info for me to read through!
So from what I'm reading, a 83-85 200x caliper will work but I will need the mounting bracket from the X to mount it up? That mounting bracket will fit my stock 250 axle fine?
alright! What about the torque link? Will it hook up to the X caliper?
Or you get this and find the caliper mount and bolt it up.
https://m.ebay.com/itm/HONDA-ATC250R...pe!63304!US!-1
I was also told that the 85 kx 80 rear will work I don't know how accurate that is
Sent from my SM-G955U using Tapatalk
