Originally Posted by
Doug8765
This was in 2004 told me to run maxima 927 castor at 20:1 syns been out since 70s guys!? This was one of the top shifter cart motor builders . I had him build me a cr 125 for 5000.00 complete. He has won several championships
If you'll notice, Doug, as was stated (possibly more than once), if you are running sustained WOT (such as shifter carts do), then 20:1 might be something you'd consider running. That was stated in this thread. So when you talk about ratios and engine builders in a thread about a Honda ATC250R three wheeler and reference information that pertains to shifter carts, you might want to open with something like "My friend who builds shifter cart engines, not ATC250R engines, says that 20:1 is the way to go when racing shifter carts, not when riding Honda ATC250R three wheelers."
Doug8765
Tell fabaio to change jets more fuel to
Tell me yourself hunny.
So you're telling me you'd now jet fatter just to stick to your guns about running more oil which you don't need? You do realize that jetting is tuned individually to every engine, no two are exactly the same, correct? You jet to make the bike run right, not to be certain you can run an excessive amount of oil that you don't need.
By your logic Doug, I should completely forget about how my bike starts and runs, just throw that out the window, then jet it too rich so that I can run more oil.
The downside to running too much oil- waste of money, clogs exhaust, raises combustion chamber temperatures, chokes everyone behind me, fouls spark plugs, etc.
The upside to running too much oil- This is fill in the blank Doug. You tell me. You tell me why I should jet to compensate for running more oil than what's recommended by just about everyone including the oil manufacturers because I'm all ears my friend.
Poor Doug, wait until Glamy gets a load of this. I can see the memes now...
