I recently sent the top end to the machine shop and the guy said he could add the port. I talked to him yesterday and he said that he broke out the side. He said he could weld it has anyone had to do this?
Sent from my XT1635-01 using Tapatalk
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
86 tri z powervalved
85 BIG red
18 rmz250
87 lt80
19 ttr110
Many people. The correct way to do the port is weld and then drill, but you’ll be fine. Better now than having it crack later.
It sucks to get old
Just try to get them to make it look like the opposite side does on the outside so you can still get a socket in there. I don’t know what Yamaha was trying to accomplish by leaving that small amount of aluminum off of the cylinders when they cast them, but it sure has caused people a lot of grief over the years when trying to add that boost port.
The other thing I would recommend is not to get too crazy on the width of either the original port, or the one that you’ve added. I would focus more on trying to elongate them slightly. Unless you’re planning to drive it WFO all the time the risk of hogging out those ports and wreaking that cylinder aren’t worth the gains in power it will net you.
It sucks to get old
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
When I did mine, I started with a small drill bit to start the port. Then I used progressively bigger and bigger bits. Then you take a file and oval it out. I didn't have to weld anything up and it has held up fine over the years.
Sounds like mine, I don’t have any welding either and my static compression is over 185 psi at 1,200 ft., but from what I’ve heard and been told we’re the lucky ones.
I have a few theories on why some cylinders crack starting with improper shimming of the head stay as well as the mating serfaces of the cylinders and the case not being flat after years of heat cycles. The other thing I have noticed when comparing the cylinders that I have, is that the quality of the casting seems to vary between them. On the one I recently polished there are some large pores in the material where the cylinder nuts go, but on the one I have a boost port in there are no pours at all.
If you were to combine a poor casting with a stressed head stay and a warped cylinder base and then add that boost port I could see how it might become a catastrophic failure waiting to happen.
It sucks to get old
Do you guys happen to have any pics of your ports. Or some that have been welded
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
I mean where they broke through the side
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
Consider your self blessed, that you don't have my Tri-Z, could you imagine if whomever owned it before me tried to do the port work..OH GOD, would that have been a sight to see
I need all the help I can get!
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
