Results 1 to 9 of 9
Thread: Where can I find a 83 200 recoil?
    Jun 2018
    Holland Mi
    93
    Greetings again. Just bought a "project " trike....1983 Honda 200. I think Im leaning why it was ($150) so cheap!! The recoil/compression release "stuff " isn't even in it! Looking at what I did find on line, WOW! Not cheap!! What do I do as I want to keep this machine project reasonable ??!!Any suggestions where to start looking?
    Jun 2018
    Holland Mi
    93
    Greetings again. I Just bought a "project " trike....1983 Honda 200. I think Im learning why it was ($150) so cheap!! The recoil/compression release "stuff " isn't even in it! Looking at what I did find on line, WOW! Not cheap!! What do I do as I want to keep this machine project reasonable ??!!Any suggestions where to start looking?
    Also more importantly do I HAVE to have it hooked up or can I go without it? I tried pull starting it with out the compression release but was quickly reminded how SMALL those recoil handles are! OUCH! I have seen some Hondas with the much larger D handles wondering if that was why. Thanks again
    Carthage NY 250r rules
    2,355
    Yes D handle much better.
    250r rules
    Jun 2018
    Holland Mi
    93
    So then you're saying I will be able to easily pull this thing over WITH OUT the compression release component? That would really be GREAT as that would save me a bunch of $$!!
    My little "project is slowly turning into a money PIT !!
    2,355
    My wife starts the auto X without the decompression release.It will still kick back but less likely to rip the handle out of your hand.
    250r rules
    6,811
    Finding and successfully installing the compression release parts is a major PITA .
    Just pull the recoil until your just past the compression stroke and THEN give it a strong pull .
    With this method your less likely to hurt yourself and the recoil
    Jun 2018
    Holland Mi
    93
    Gotcha! Sounds like a plan ! Plus thatll save me some much needed $$ for other STUFF it needs.THANK YOU for the advice !! So now then Im guessing a snowmobile recoil handle would work?
    This machines pretty rough shape as the previous owner worked on it, left it for dead , then left it outside for YEARS! So now its my personal GOAL to get this baby ROLLIN! Thanks again for your help
    Jun 2018
    Holland Mi
    93
    Thanks ~! Shortline 10 !! I tried it and it worked like a charm ! I was so distracted by the issues of weak spark and crappy recoil I just figured Id have to pull my guts out every time . BUT We are slowly getting things better here thanks to TWW!
    Apr 2014
    Edmond, KS
    2,591
    We will absolutely refuse to answer any more questions without pictures! Just kidding. We will answer, but we always like pictures too.
