Results 1 to 7 of 7
Thread: 350x electrical lighting question...blew out update
    Lewiston, N.Y.
    1,477
    Just bought a set of 80w l.e.d.s for the 350x https://m.ebay.com/itm/2X-80W-H6M-H6....c100891.m5206 - buddy has them on his 250sx and look killer. My question is - do I need any sort of resistor since the 350x doesn't have a battery?
    6,801
    350x has a voltage regulator so they should be ok with no battery , just give it a try , if theirs an issue at idle we’re theirs not enough wattage then you might look into installing a battery .
    Lewiston, N.Y.
    1,477
    Hey thanks for the reply shortline! Been a few!
    I just did some quick reading on this prior to posting and I guess the issue was not so much at idle but under higher rpm. Oh well I will run 'em.
    Worcester, MA
    1,117
    Nice. Let us know how it works out. I'm interested in better lighting and even adding a battery on a 350x
    Jun 2009
    Leander TX
    2,217
    I run a couple of 18W LED cubes on my 350X along with 35W Halogen bulbs in the stock headlights.
    I just plugged them in and run them off the AC lighting system.
    Lewiston, N.Y.
    1,477
    Ok well I installed them today. They lit up and lasted about 15 seconds then went dark. Will not work in high or low beam so I'm assuming they blew out. Any idea how to make these work or what went wrong?
    The Open Road
    4,736
    I've heard some LEDs don't like AC voltage and some do. Maybe that's the issue.
    That rumor was precisely the reason I put a battery and a regulator/rectifier on my 200X to run mine.
