Results 1 to 2 of 2
Thread: 1973-74 Honda ATC 90 Coil
    bmw1 is offline New to the board Arm chair racerNew to the board
    May 2018
    Minnesota
    12
    Where can I get a reasonably priced coil for a 1973-74 ATC 90?
    I found this http://dratv.com/untecco6vacw.html
    Has anyone tried it?
    I was trying to figure out why the ATC 90 above did not have spark. Pulled out the coil assembly to replace condenser. Put new condenser on. When I was putting the coil assembly back in I was gently pulling on the spark plug wire to get the coil assembly to line up and the spark plug wire came out of the coil.
    Doesn't seem like it can be just pushed back in either.
    Any ideas on how to fix?
    Will the coil above work?
    The existing coil says NIPPONDENSO 029700.
    Thanks.
    Mar 2021
    San Diego
    Sorry but did you ever fix your problem? Thanks
