Results 1 to 9 of 9
Thread: 200ES ATC Heaven CDI?
    Jun 2018
    Southern Utah
    3
    My 200ES doesn't have spark and I've been looking for CDIs everywhere and came across a new one from ATC Heaven. It says it is just like the OE one but the torque curve and rev limiter are different.
    Anyone have any experience with these or know what the difference is in the torque curve and rev limiter? Thanks in advance.
    Northern, California US
    105
    Quote Originally Posted by LobsterBush View Post
    Are you sure its the CDI thats causing no spark, Ive seen many bikes with no spark, very rarely is it the CDI. I have no experience with ATC heaven CDI, but Im betting your CDI is not your problem.
    Oh yeah welcome to the board.
    Apr 2014
    Australia
    580
    I had the same problem with my 200es also! Have you tried to clean or sand the frame where the coil links to the frame! Might be rusty try that! Mine didn’t have spark last weekend I just cleaned up! How starts
    Jun 2018
    Southern Utah
    3
    Quote Originally Posted by Dirtcloud View Post
    I've checked resistance on the coil and I have checked the resistance coming from the plug that plugs into the cdi and everything is looking decent there. Slowly narrowing it down to the cdi.
    Trike
    1984 ATC 200ES Big Red
    Non-Trikes
    2015 Yamaha FZ-07
    1992 Ford F250
    Apr 2014
    Edmond, KS
    2,591
    I think the 200ES had issues with the CDI. Since it's a one year only model, it's kind of hard to find an OEM one.
    6,815
    If it’s an 84es the CDI is still available threw Honda .
    105
    If you have a service manual check the stator output.
    Jun 2018
    Southern Utah
    3
    Might be putting my electrical issues on hold for a bit. Was turning to TDC to check valves and my timing chain and a bolt in my cam sprocket decided they wanted to break..
    Trike
    Non-Trikes
    2015 Yamaha FZ-07
    1992 Ford F250
    Jan 2014
    La
    1,062
    have you physically inspected the spark advancer the springs like to break causing a no spark issue even though the spark advancer checks out with a multimeter?
