ENGINE WILL NOT TURN ALL THE WAY AROUND, Something stopping it. I can turn it by hand just about all the way around and back...when it stops = the clutch can be spun ..Thought's![]()
250r dust runner
I think your timing is off and the piston is hitting a valve Or you have a valve sticking open.
250r rules
chain looks tight but I will check, thank you
250r dust runner
Are you trying to turn the engine with the clutch? If so, is it possible that the engine stops turning at TDC on the compression stroke allowing the clutch to "slip"?
no, turning the crankshaft. so many projects o.m.g. I gotta stop buying stuff...WOW
250r dust runner
250r dust runner
Interesting to see what it is...
'83 200X
250r dust runner
250r dust runner
250r dust runner
250r dust runner
