Results 1 to 3 of 3
Thread: 1982 Atc 110 runs awesome...except...
    May 2013
    Broome county, NY.
    120
    Hey guys,
    I recently picked up a gorgeous little 1982 Atc 110.
    It runs very very nice, however there is this one little spot just off idle that it seems to sputter a bit. If riding at a normal pace it is not even noticeable, but when putting around very very slowly in low range, in 1st gear it becomes quite noticeable.
    Again this is just one little spot just off idle. Every other spot is absolutely perfect. Is there anything I can do to fix this or is it nature of the beast with these little 110’s?
    It only bothers me because I spend most of my time putting very very slowly when I opt to ride the 110.
    Thanks in advance.
    John.
    6,817
    Great score!!!!
    I would service the carburetor to make sure that’s 100% (shindy carburetor kit only ) , the slide needle controls the first 1/4 throttle so you can move the clip up or down to see if any improvement .
    New spark plug and air filter can’t hurt either .
    May 2013
    Broome county, NY.
    120
    Thanks for your reply.
