Results 1 to 7 of 7
Thread: Axle carrier bolts?
    Jul 2018
    St. Clair Shores, MI Grayling, MI
    67
    Axle carrier bolts?
    Hey all. Still new to 3 wheelers and all the different parts. I knew I had slight play with the drive chain but suddenly it was extremely worse this weekend. I decided to take a look and to my surprise the left 2 axle carrier bolts are a problem. Top bolt/nut missing and bottom left very loose. I'll add that the "adjustment nut" is rusted on and won't adjust. So my questions...
    1. What size nut and bolts would I need to purchase? Anything special with them?
    2. Easy fix for bad threaded adjust nut that is seized?
    3. Installation suggestions?
    I'd appreciate any help. Thanks in advance.
    '84 Honda 200x ATC
    '84 Honda 200m ATC
    '85 Honda 200s ATC
    '85 Honda 125m ATC
    6,798
    Check partzilla.com
    Bolts are probably still available new .
    Jul 2018
    67
    Check partzilla.com
    Thanks for the suggestion. I sent off an email to see if they can help me.
    '84 Honda 200x ATC
    '84 Honda 200m ATC
    '85 Honda 200s ATC
    '85 Honda 125m ATC
    Jun 2009
    Leander TX
    2,217
    If they can't help through e-mail, check out this diagram.
    https://www.partzilla.com/catalog/ho...ear-brake-drum
    Looks like you need either a #16 or #17.
    No longer available.
    At least Honda tells you size and how long: M12x25 or M12x28.
    Do you have any of the old bolts? You can use them to figure out if your threads are still good, what the thread pitch is, if they have a flange head or normal, and what kind of washers you need.
    I can't remember Honda M12 thread pitch - maybe M12x1.50 or M12x1.25?
    They probably have a lock washer on them, too.
    Jun 2009
    Leander TX
    2,217
    I'd be tempted to buy something like this just to see if I got lucky:
    https://www.ebay.com/itm/1984-HONDA-...LH_TitleDesc=0
    Jul 2018
    67
    Thanks! Yes I have only one missing so I can take it to my local custom bolt/screw place hopefully have them match it. Appreciate your help.
    '84 Honda 200x ATC
    '84 Honda 200m ATC
    '85 Honda 200s ATC
    '85 Honda 125m ATC
    Sep 2017
    ON
    8
    I cut the old nuts off the carrier and welded.new ones then bought new bolts
    Sent from my ONEPLUS A5000 using Tapatalk
