Results 1 to 15 of 16
Thread: Hi I'm paul i have a 1984 200x with valve train noise
    Aug 2018
    Sedro woolley
    37
    I have rebuilt the top end with a 67 mm piston and a
    reground cam from web cams. One stage below RACING. I adjust valves to factory specs still have noise. Is it common to have noise with a bigger cam.
    6,811
    Your cam journals are probably worn .
    You can run a straight weight 40 or 50 weight oil which should help .
    Did you replace the cam chain and set the tension ?
    Aug 2018
    Sedro woolley
    37
    Yes replaced chain and tensioner. Not hearing chain noise just valve tick
    Aug 2018
    Sedro woolley
    37
    Cam journals are tight. runs great noisy at idle
    Aug 2018
    Sedro woolley
    37
    Thanks for the information. you or anyone else think of something I'm missing thanks for the reply
    May 2015
    San Diego, CA
    1,800
    Quote Originally Posted by Paul G View Post
    What kind of noise? Rocker/chain/valve/etc? Here's a video of my noise. sound anything like that?
    https://youtu.be/fkXQYeZ0EH8
    Aug 2018
    Sedro woolley
    37
    Thanks for the reply. Mine does sound like yours. Are you running a bigger cam and valve springs. I just ordered a new cam bearing bushing. Clean bike you have.
    Aug 2018
    Sedro woolley
    37
    Oh and I do believe it is rocker noise.
    May 2015
    San Diego, CA
    1,800
    In my case I chalked it up to the rockers being too loosey goosey.
    Everything was stock. Keep in mind these 200X engines have low oil pressure so the valveline seems to suffer the most.
    Aug 2018
    Sedro woolley
    37
    Ok! think I'll put the new cam bushing in. there was a tinny bit of slop in it. And start from the beginning maybe run some 20 /50 wt
    Aug 2018
    Sedro woolley
    37
ID:	254054 going to paint while i wait for engine parts.
    Aug 2018
    Sedro woolley
    37
    Has anybody herd of a yamahonki ?
ID:	254055 i bought this atc converted to a quad. A couple years ago. Never seen or heard of any other.
    Aug 2018
    Sedro woolley
    37
ID:	254056 this is what a yamahonki looks like. Or what my Sons looks like.
    Apr 2014
    Edmond, KS
    2,591
    Well at least I can see where the mane comes from. What trike was it based off of?
    Aug 2018
    Sedro woolley
    37
    Honda 200x frame with a suzuki quad racer 250 front end. Yamaha tri z 250 motor. I think the motor was built for racing it gets up and goes.
