hi all picked up a 1982 200a last year and did a few mods ( 12x28 mudzillas, snorkle, and 52 tooth rear sprocket). a few weeks ago it was getting pretty noisy (piston slap). pulled motor down ordered 65.5mm piston had cylinder bored out, re assembled. i guess i should mention i am a marine and motorcycle technician so far far from my first build or first performance build. cannot get this darn thing to run properly got it jetted i believe to be pretty darn close but it almost seams like i need a bigger carb has anyone else put in a 65.5mm top end and if so did you go with a 30mm carb? money is tight and i dont really want to buy it just for s&g and it not make the difference. thanks for any info.
