Results 1 to 15 of 24
Thread: 1982 200a with 65.5mm piston
    Apr 2018
    thamesville, ontario
    17
    hi all picked up a 1982 200a last year and did a few mods ( 12x28 mudzillas, snorkle, and 52 tooth rear sprocket). a few weeks ago it was getting pretty noisy (piston slap). pulled motor down ordered 65.5mm piston had cylinder bored out, re assembled. i guess i should mention i am a marine and motorcycle technician so far far from my first build or first performance build. cannot get this darn thing to run properly got it jetted i believe to be pretty darn close but it almost seams like i need a bigger carb has anyone else put in a 65.5mm top end and if so did you go with a 30mm carb? money is tight and i dont really want to buy it just for s&g and it not make the difference. thanks for any info.
    2,591
    I'm no expert on carbs, but I'd guess that a 30mm is way too big. Yours is probably a 22mm, while a 200X carb is 24mm. What is it doing to make you feel that it needs a bigger carb? What other mods did you do to it?
    Apr 2018
    17
    My 200a has a stock 24mm carb I do not remember off the top of my head what the standard bore is. 1st over for a 200x is 65mm bore and from what I have read on this forum it has a 27mm carb and guys are putting on xr200 carbs to pick them up which are a 30mm carb. I bored my cylinder to 65.5mm with a cam not sure what the cam is it was in a parts bike I bought and was lumpier than mine so I put it in upon assembly. Seeing as the guys running 200x are putting the xr200 carb on theirs at a 65mm bore I would assume I am. Going to need to xr200 carb with my 65.5mm bore but was hoping to get some confirmation
    2,591
    Well on the home page , on the left hand side, there is a link for Honda specs and brochures. According to this link, all of the 185s and auto clutch 200's have a 22mm carb stock. If yours has a stock Kehien carb that's 24mm, then it probably came off of a 200X. Just because you have a larger bore, you don't have to use a larger carb. You also have a bigger cam. You're getting there. Compression ratio? The 200X has a higher compression ratio than a auto clutch 200. How about the intake and exhaust/ You will need to be able to flow the amount of air that a 30mm carb will let through. If I'm not saying things that you like, try giving shortline10 or YaegerB a pm. They know A LOT more about the 200X than I do. They also know what to do to get more power out of them. Most of the performance ideas will carry over to your engine as well.
    Apr 2018
    17
    ok thank you for the info yes i found that my buddy has a 200x and we pulled and measured his car which is a 24mm carb. the parts bike i purchased had a slightly bigger carb on it it was a 25 or 26mm cannot recall off the top of my head. as far as compression ratio i am unsure what the compression ratio is with the new piston. as far as exhaust i cannot find a used dg or cobra near me without spending big money so i am currently working on building a custom 1 1/8" exhaust for it thank you for the info. i will try and contact him and see what he has to say.
    Jul 2018
    TN
    1,065
    Ok, I googled a couple of times and found squat. Post a picture if you have the time and inclination. I have never heard of or seen a 200'A'. Seen ATC, S, M, E, ES & X but never an A. I love seeing something new.
    2,591
    My guess is that it was a typo since the a and s keys are next to each other. Coreyp01, awesome on the exhaust. Post up some pics when you're done. I'd like to see it and others will too.
    Aug 2018
    Sedro woolley
    37
    I would like to ask if you used the head and rocker cover off the bike you took the cam from. Science you don't know the size of the cam it's possible the valve spring could be diffrent. I had to change mine when I went with a bigger cam. Could possibly be floating the valves at higher rpm. Causing lack of performance.
    Apr 2018
    17
    i will post up a picture of it tonight if i get a chance. i believe it be be a 200a because of the parts fiches in 82 they only show a 200a , 200ea, and 250ra. i will definatly post up some pictures when i am done i may post a new thread on the build start to fish to show the guys and gals how i did it if some one else was interested in doing the same or similar, hopefully starting on that tonight. i do have the head and cover for the other motor. i believe them to be stock length but i will defiantly double check. i do not believe that to be my problem. i cannot get any throttle response out of it and getting very little torque. i have played with jetting back and forth like cazy but i cannot get it to not foul plugs with anything more than a 92.5 main which is light to me as far as i am concerned, hence why i am leaning towards bigger carb (more air in) and exhaust (more air out).
    Jul 2018
    TN
    1,065
    Quote Originally Posted by coreyp01 View Post
    Wonder if that's a canadian market only thing cause I never heard of any of those models.
    This is a Honda right? Can't wait to see a picture of it.
    Apr 2018
    17
    Here a picture I have of it when I changed my rear sprocket. Yes it is a Honda. Altho the tank is off of a yamaha moto 4. I also put the rear rack on it.
    Sent from my LG-H873 using Tapatalk
    Aug 2018
    Sedro woolley
    37
    I had similar problem with a Honda 100 dirt bike never fouled plugs i rebuilt top end. It would cut out when throttle up and no torque. Friend of mine bought it from me and sent it to a shop. It had to do something with timing or the points. I checked the timing a couple of times I must have missed something. You could check that also. That was a few years ago he still rides it. I go over sometime a and ride it to. I'll keep thinking !
    Aug 2018
    Sedro woolley
    37
    What color is your spark plug after you run it white or brown or black. that's a good indication of fuel mixture. Maybe vacume leak?
    Apr 2018
    17
    I marked the Tim NG plate when I took it off but it's definitely worth double checking with a light. If I run a 90 main my plug is white (lean) and anything over a 92 is black (rich). I stole a carb off a buddies dads 200x which has been sitting for 10 years but he will not part with. I am going to clean it and try it be Use altho it measures the same as my carb it Is a slightly different carb so we will see how that works out
    Aug 2018
    Sedro woolley
    37
    Good luck hope it works out.��
