Results 1 to 9 of 9
Thread: Tecate Guys . . .
    Dec 2002
    749
    Tecate Guys . . .
    Could anyone give me some info here. The 86 T3 is fouling plugs really quick and they come out all black. That means it is getting running rich, or the gas mixture has to much oil in it, right? Right now I am running 40:1 in it.
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
    Mar 2003
    Camden NY
    76
    that should be an easy fix. first i would check if it is runing rich or not. find out what mix is right if your not shur. i would say it is runing rich. my old 250 used to do that. should't be a big deal.
    Tyler A
    "00" scrambler 500 4+4
    K&N air filter, hand gards, racks and rear black water tires on aluminum wheels.
    (Dads)
    "00" sportsman 500 4+4
    winch, hand warmers and two up seat.
    Dec 2002
    749
    Its a big deal if you have to change the plugs every day!
    Jul 2003
    936
    mine started doing that too..right after a carb cleaning of all things...and i have no clue what is going on....havent tried to fix it yet i was gona get on that soon....tryin to figure it out...
    Wanna race? ;-)
    85' Tecate (still looking for entire front brake asembly...)
    bonanza mini-bike
    if you cant ride with the big boys...put it back on the trailer
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    I would think the carb is out of adjustment.
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    The oil ratio should have a minimal effect especially at a thin 40:1 mix. Most likely something else is to blame... have you recently changed anything? If not then my first thought is to check your air filter. If it is clogged or dirty you will run rich. Most other maladies will make you run lean. Things like air leaks or clogged jets etc...
    Curtis
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
    JMiller's Avatar
    JMiller is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    My 87 was doing this. I rebuilt the whole motor replaced the carb, everything except the stator was replaced because it looked new. Well, it turned out to be the stator and cdi.
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    Mar 2003
    NJ
    911
    Jmiller,
    what did you end up using? kx or ricky stator?
    i hear these go bad a lot on tecates. i dont know if mine was changed.
    thanks,
    mark
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    Dec 2002
    749
    How can I tell whether it is the stator or not? Thanks for the tips guys.
