Results 1 to 13 of 13
Thread: PWK33 jetting
    Apr 2014
    Australia
    580
    PWK33 jetting
    Hey guys having dramas again with my trike from the bike shop. I have a 84 250r with boyseen reeds, full DG exhaust and silencer with a pwk33 carb on it. The bike shop has put a 52 and a 158 in it and it’s fouling plugs and not idling. Has anyone done this to their 250r and give me a rough on what jetting to put in? Change the 52 pilot smaller?
    Just maybe a rough ball park figure where to start? Thanks
    Slidell, LA
    4,738
    Hey Ivan, I replied to your PM. Air screw out 1.5 turns from seated. Start with 45 pilot and see how it responds. It may need to be bigger than that but it’s a good place to start. Needle clip in middle.
    The Open Road
    4,736
    Good to see you posting
    Apr 2014
    Australia
    580
    Thanks Brendan I’ll try out on the weekend and do it myself!
    N.E. Ohio
    2,002
    What's your mix ratio and brand synthetic or not? If your a 32:1 guy your a bit rich on blend, on 86*octane IMO, and bad idle/failed plugs can be a result. I prefer non-ethanol fuel as well but that's me 40:1 synthetic. It's running now so your close use the needle clip position to determine your next move. Small adjustments, don't jump around with jets get your direction frist moving the clip. Yes it's a pain but worth it. When moving up or down a main jet always put the clip back to the middle position. Then start the process all over, you'll get it.
    Apr 2014
    Australia
    580
    Quote Originally Posted by Tri-Z 250 View Post
    Yes running 32 to 1 using moto oil. I’ll play around on the weekend and hopefully get it sorted out.
    Apr 2014
    Australia
    580
    Jetting seems to be fine and run ok, but it still won’t idle correctly! Sometimes it idles nice them other times, it seems like it’s missing a beat, then sort of rev high then low with the idle? What to do? I think iam over this trike, so much time and effort into it and still won’t work! I think it’s time to sell and buy a third gen here if I can find one.
    ATCKevin's Avatar
    ATCKevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2018
    Michigan
    179
    Erratic idle could mean an air leak somewhere. Might have to look into a crankcase pressure test.
    Apr 2014
    Australia
    580
    Quote Originally Posted by ATCKevin View Post
    That’s what I think! Must be a leak somewhere
    oldoo's Avatar
    oldoo is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2017
    Australia
    155
    My gut says air leak man...
    Hopefully old mate can diagnose where it is. It would make sense for it to be the cause as you had the jumpy idle with the previous carb yeah??
    Apr 2014
    Australia
    580
    Quote Originally Posted by oldoo View Post
    Yeah man it has to be a air leak! Brendan messaged me today also and said the same thing! So over this trike, but will have to get it working once and for all.
    oldoo's Avatar
    May 2017
    Australia
    155
    Once that's fixed it should run sweet!
    Apr 2014
    Australia
    580
    Let’s hope so buddy! I still have my doubts with this bike it’s just caused me dramas from day one! Regret buying it! All the work and money, but will sort it out
