Originally Posted by
Tri-Z 250
What's your mix ratio and brand synthetic or not? If your a 32:1 guy your a bit rich on blend, on 86*octane IMO, and bad idle/failed plugs can be a result. I prefer non-ethanol fuel as well but that's me 40:1 synthetic. It's running now so your close use the needle clip position to determine your next move. Small adjustments, don't jump around with jets get your direction frist moving the clip. Yes it's a pain but worth it. When moving up or down a main jet always put the clip back to the middle position. Then start the process all over, you'll get it.
