Results 1 to 15 of 16
Thread: 84 200x cam problems
    May 2018
    Lewis County NY
    32
    Trying to install camshaft and everything goes together well until I tightened the two bolts that hold the cdi housing to the head. Once those bolts are tight you can barely spin the motor over at all. It's basically Rock solid. When the bolts are loosened it can spin over again. Can't figure it out but it seems like it's binding the cam up somehow. Anybody got any ideas?
    6,811
    New cam ? Did you replace the inner cam bushing ?
    Might not be seated correctly . Pretty common problem .
    May 2018
    Lewis County NY
    32
    Cam is not new. Just putting engine back together again. Bushing and thrust washer are both installed correctly
    Sep 2007
    100mi west of Chicago
    3,582
    Can you post some pics? Been a while since I've been in one of those motors. Can't picture it.
    Rob
    The Open Road
    4,736
    Is your CDI rotor pushed all the way onto the cam and locked into that pin?
    If it's not, it might be sticking out too far and binding up the works.
    I'm confused though... Is it the CDI cover itself that's binding when you tighten it or is it the CDI base that goes under the cover between it and the head?
    6,811
    Better recheck that bushing , theirs nothing else that could be causing it to not fully go in straight .
    Quote Originally Posted by HON-DUH View Post
    May 2018
    Lewis County NY
    32
    Cdi rotor is not installed yet. Just the cdi base and once the two bolts are tight it binds the engine upClick image for larger version.
    May 2018
    Lewis County NY
    32
    Attachment 254294 here is a pic without base installed
    Feb 2003
    Australia
    927
    Are they the correct cam bolts? If they are too long that will bind up the cam when the outer case is tightened up.
    I've had issues like this before. In some cases I used Dykem blue layout Ink, sprayed everything and as I tightened things, the ink rubs on the tolerance that is too tight, and shows me the issue.
    I'm leaning more towards you're missing something easy, or we are missing another variable...
    May 2018
    Lewis County NY
    32
    I know that the bolts are the correct ones. I have a spare head from a parts motor that I am going to try next and see if that does anything. This issue has just got me completely stumped. Never thought i would run into such a stupid roadblock on this project
    Leevvii's Avatar
    Leevvii is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2016
    Australia
    216
    there is a gasket and o'ring that sits behind the base cover, are they installed? If not, it may pull the cover in too far and bind, just a guess.
    n
    Did ya get it bud?? Report back, we all gotta know these little things so we can help/share with others...
    May 2018
    Lewis County NY
    32
    Haven't made any progress. I plan on trying to put a different head on it from a parts motor i have but havent gotten around to it yet. I'm still trying to come up with an explanation for what could possibly be causing this issue. Just can't make sense of it
    May 2018
    Lewis County NY
    32
    Finally solved this issue that has been plagueing me for the past year. Turns out it was the housing for the cdi. I had another one laying around and I thought I'd try it just for laughs and it went on and everything spin freely as it should. Couldn't figure out the issue with the old one though. Looked it over well and couldn't see a problem. But anyways just wanted to update
