Results 1 to 6 of 6
Thread: YTM225 Voltage Draw?
    Six Stroke's Avatar
    Six Stroke is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central Minnesota
    315
    Friends, Romans, Honda Men, lend me your ears...
    Been a while, and I have returned with an alleged voltage draw on my 225dx. The battery stays up when it’s out of the trike, but something is pulling it down when it’s hooked up. What could it even be? It’s not like there’s a dome light. Hypothetically everything should be off when the key is off, no?
    1985 Yamaha YTM225DX
    2014 Yamaha WR450F
    2008 Yamaha TW200
    1975 Honda CB400F
    The Open Road
    4,727
    I don't know the fix or cause but I'll bump the thread at least
    I will say there should be no draw with the ignition off. No sense having a battery that won't stay charged.
    Apr 2017
    Tucson, Az
    42
    Will the brake light work with the key off? If so that could be your draw.
    Six Stroke's Avatar
    Central Minnesota
    315
    There’s no brake light period, so that shouldn’t be an issue. I'm going to pick up a voltmeter today and test the battery daily both in and out of the trike. See what kind of numbers I get.
    2014 Yamaha WR450F
    2008 Yamaha TW200
    1975 Honda CB400F
    Six Stroke's Avatar
    Central Minnesota
    315
    Here’s my recorded voltages. Not as different as I expected.
    2014 Yamaha WR450F
    2008 Yamaha TW200
    1975 Honda CB400F
    Jul 2017
    Pennsylvania
    71
    Without the wiring diagram in front of me I cannot pin point what all it could be but issues like this can be troublesome. Just because you have the Ignition switch off there it still a load going to the switch. So everything in between could be an issue (wires included). I would start with checking the grounding station off the battery. Second I would take the fuse out coming off the battery and keeping checking it like you were. By taking out the fuse you are eliminating everything past the fuse for a short that could be causing a drain. It could be somthing like a nicked wire touching the frame. So pay close attention where wires are tied together or touching something. Zip ties are known for doing this. Old splices as well.
