Most of the mounts on my Tri z frame are stripped out what do you guys do to fix them
Sent from my XT1635-01 using Tapatalk
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
86 tri z powervalved
85 BIG red
18 rmz250
87 lt80
19 ttr110
Never had to do it, but I did replace the front motor mount bolt with an 8 mm bolt. Is there enough meat there for you to drill them out and tap them to 8 mm?
It sucks to get old
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
I'm surprised nobody has tried these for the peg mounts
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
Years ago, I was making threaded spacers.
I cut off the complete stock mount, remove the junk threaded collar they use, insert mine, weld it up, then weld onto the frame, fixed forever.
Did a few, then people started repairing the threads as a cheap fix, it doesn't last..
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
85 BIG red
18 rmz250
87 lt80
19 ttr110
- Drill the correct sized hole same size, or .002" smaller than the rivnut diameter
- Put a little anti-seize on a 20mm long socket cap bolt. Length doesn't matter as long as its long enough
- Hold the bolt and spin a nut half way up the bolt thread, then a flat washer and thread the bolt into the rivnut (so, bolt, nut, washer rivnut)
- Gently tap the rivnut into the hole
- Spin the nut down till the washer is snug against the head of the rivnut
- Hold the bolt with an Allan key and turn the nut down with a wrench. This draws the rivnut up against the back of the mounting surface
- When it's properly mushroomed you can back out the bolt and do another one
You'll want to practice a bit till you get the feel for it. It doesn't take much and you don't want to overdo it.
It sucks to get old
