Results 1 to 7 of 7
Thread: Compression testing
    Jul 2018
    TN
    1,065
    Compression testing
    1984 200ES
    The book says 156 psi
    It also says the compression ratio is 7.8:1
    That doesn't add up so what am I missing?
    Typical atmospheric pressure is 14.7 psi which would be a 1:1.
    7.8 multiplied by 14.7 equals 114.66psi
    156 psi would be about 10.5:1
    So what am I missing?
    I just picked up another 200Es and it won't run. It has some spark issues but the compression test reads 100PSI dead cold. That would be 6.8:1 and it would climb once oil circulates and everything expands. I know I need to rebuild it and I will eventually but I'd like to get it running and square away some other issues first. It has been sitting the better part of a decade. Anyway.
    What am I failing to understand here? Cause if 156psi equals 10.5:1 then why does the 'high compression' pistons from Wiseco say 10.5:1?
    Apr 2014
    Edmond, KS
    2,591
    I don't know how to explain it, but the 156 PSI would probably be 7.8:1. When you did the compression test on your new 200ES, did you hold the throttle open? You need to do this in order to get an accurate reading. Just for fun, I did this a while back on a YTM225DR I had. with ho throttle, it tested at 105PSI. I got 165 PSI by holding the throttle open. Big difference.
    Jul 2018
    TN
    1,065
    I guess the whole point is moot, I just got it running. I let it run for a minute or two. I couldn't see my neighbor's house. Seriously. It was bad!
    Top end will HAVE to be gone through.
    Connecticut
    1,605
    Drain the oil and see if it is milky. I have had some condensation/water in oil from a machine that sat forever and as soon as I changed the oil smoke goes away.
    Mexico
    9,020
    Google the difference between compression and cylinder pressure (might want to take an Advil first)
    There’s static compression and dynamic compression. On a four stroke your piston might might have an advertised static ratio of 12 to 1, but a big cam with lots of overlap can bleed off enough pressure that it will run on pump gas.
    Another thing to keep in mind is that your compression gauge is almost as unique as a fingerprint in that you won’t always get exactly the same reading from two different ones on the same engine. A 2 to 5 psi difference between two gauges that cost under $30 bucks wouldn’t surprise me.
    It sucks to get old
    May 2009
    S.E. Michigan
    1,251
    Here is a link:
    https://en.wikipedia.org/wiki/Compre...pressure_ratio
    Even if you don't read the words, there is a graph and table that explains it. The key is that compression ratio is a comparison of the volume in the cylinder. Volume changes do not correlate 1:1 with pressure changes.
    There is an exponent that depends on the medium (air in this case).
    Here is the theoretical table (sorry, formatting doesn't paste well):
    Compression ratio 2:1 3:1 5:1 10:1 15:1 20:1 25:1 35:1
    Pressure ratio 2.64:1 4.66:1 9.52:1 25.12:1 44.31:1 66.29:1 90.60:1 145.11:1
    At 7.8:1 compression ratio, your pressure ratio (theoretical ideal) is 17.7. So your 14.7 PSI atmospheric pressure would give 260 PSI at TDC.
    Some reasons you don't get this high of pressure:
    -The valves are not closed at the instant the piston is at BDC. There is time when the piston is still moving up with valves open, so you aren't capturing all the air indicated by compression ratio (compares TDC to BDC)
    - Rings are not perfect and leak
    - Throttle and intake provide restriction preventing perfect atmospheric pressure in the cylinder at BDC
    - Thermal transfer into or out of the cylinder. The pressure ratio assumes no heat is added or taken away. Air will get hot when you compress it. The ideal theory says that nothing happens to alter this natural increase in temperature.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Jul 2018
    TN
    1,065
    Cameixan is right, anyone got an advil...or some vicodin.
