Results 1 to 2 of 2
Thread: 85 250es trouble starting
    Jan 2018
    mass
    the bike runs fine it just wont start on its own, I have to squirt fuel into the cylinder then it will start and run fine on its own, but wont restart until you put fuel in the cylinder again
    NEPA
    7,049
    Carb needs cleaned,and most likely needs the "starter jet" drilled out for the cold start update. Read this,and you will know everything you ever need to know about a ES/SX/TRX carb.http://www.3wheelerworld.com/archive.../t-161746.html
