Results 1 to 15 of 28
Thread: Why haven’t more people done the 200x decompression mod????
    Nov 2012
    ny
    55
    83-85 200x kick start gears are a known problem. The valve cover off a 185/200 (with decompression lever) will bolt up to the 200x (so I’ve read) and solve the problem of continued stress on the gears. Why haven’t I’ve seen more info on this? Seems like it would solve the problem
    6,790
    The 200x cam won’t work with the decompression setup and the 185/200 cam is a lesser aggressive cam so your going backwards on performance .
    Nov 2012
    ny
    55
    Thx for reply. Is this Wrong info??? http://www.3wheelerworld.com/showthr...sion-lever-mod. I hope not because I ordered my valve cover
    6,790
    The valve cover will bolt on but you will need a cam designed to work with the decompression setup .
    Nov 2012
    ny
    55
    Why special cam? The decompression lever hooks to exhaust rocker. When you move the lever it moves the rocker which presses down on the exhaust valve. Shouldn’t that work?
    6,790
    The back side of the cam lobes I believe are machined smaller on the 200x and most performance cams so the lever won’t open the exhaust valve .
    Go ahead and give it a try , maybe I’m wrong lol .
    I’ve installed a lot of performance cams in the 185/200 series motors and it always caused the compression release to not function anymore .
    Nov 2012
    ny
    55
    Hope you didn’t take my reply wrong? Wasn’t trying to sound like I know what I’m talking about lol. I’m just trying to understand how the lever really works? Not sure what you mean about the cam lobes being smaller. How does that affect the lever not pressing down on the valve? I’m trying to prevent the known failure of the kick starter. Appreciate the info!!
    Leevvii's Avatar
    Leevvii is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2016
    Australia
    216
    I asked the same question recently , and have a 200 es cover, so im keen to know how this pans out, PLEASE keep us posted. I would assume if it is possible to do it, alot of folks here would have already done it, im not holding my breath but it would be a very handy mod if it is possible. Sadly, i dont think its possible to check the operation of the lever with the motor disassembled, but i might be wrong, good luck. I also assume that the "cam" on the decomp'er uses the lobe of the camshaft as a "pivot" of sorts, to stop it flexing when rotated, so the smaller diameter camshaft lobe would prevent this occurring with the X cam, and hence, no decomp, just a guess.
    n
    Nov 2012
    ny
    55
    Take a look at your cover to see how the lever functions to see what you think. Anybody know the diff in hp between a decompression cam style vs 200x cam? I would think it wouldn’t be that Much? Also would the decompression style cam out of a 185/200e ect be a direct bolt in? To me it would be worth the swap to save the kick start gears. It’s never gonna be a speed demon lol. Maybe upgrade the carb/intake to make up the hp diff. Splitting the case much less finding the upgraded gears would be a pain in the a— . Mine makes a single click noise I’d say 1-2 times out of every 10 kicks, I assuming that’s my gears right? I know I’ve read something about the spring or something. Any info would be great!
    Nov 2012
    ny
    55
    Found this on youtube. Wonder what that grove on the 200x cam is for? Sounds like the cams are interchangeable? Someone with knowledge plz chime in to confirm. If theres min performance difference and its a direct boltin im thinking im gonna put a decompression style cam in. https://www.youtube.com/watch?v=BbNiLAHBynw
    Feb 2003
    Australia
    927
    If the 200x cam wont actuate the decomp rocker, try using an XR200 cam. They also have the decomp and some blokes use those cams as a cheap performance mod.
    Nov 2012
    ny
    55
    That was my next question. Has anyone installed a xr200 cam in 200 and still had the decompression leval work? I’m hoping townline chimes in as he has installed a lot of cams in different machines. I really don’t want to buy one/install to find out that it won’t work. Im a bit confused on how a lower cam lobe will allow the lever to work?
    TexFest's Avatar
    TexFest is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    U.S.
    339
    the xr200 valve cover also has a decompression, try that maybe, they look pretty cheap on ebay
    TPC 450R
    Nov 2012
    ny
    55
    Ill check into that. Anybody with more info on xr setup let me know thx
    Nov 2012
    ny
    55
    I just ordered a 200e cam with matching valve cover. Will keep you guys undated!
