Results 1 to 9 of 9
Thread: YFZ - Banshee Drive Hub Interchangeability
    Mexico
    9,019
    Does anyone know if the splines on the sprocket hub of a YFZ450 are the same as those on a Banshee axle? I know nothing else is the same on the two hubs, I just need to know if the YFZ hub fits the Banshee splines.
    Thank you
    It sucks to get old
    Slidell, LA
    4,738
    Yes they should be interchangeable. I believe they are all 24 spline.
    Williamstown PA
    5,825
    Just buy a banshee one, plenty out there, warrior and blaster are the same too last i knew. Bolt up a sprocket quard and go about your day.
    Mexico
    9,019
    Thanks. I already have a Banshee hub. I need to either modify it or replace it to suit my project.
    It sucks to get old
    devore,ca
    1,056
    There is some differences in the YFZ axle components depending on year model. It started changing in 2009/2010. I believe the drive hub splines and / or diameter was one of them.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Mexico
    9,019
    I had .200” milled off the Banshee hub. That should be good enough.
    It sucks to get old
    Williamstown PA
    5,825
    Make your own sprocket guard for that ting off something on ebay for a TRX450R...you will enjoy it.
    Mexico
    9,019
    One of those round plastic discs? Been meaning to look into those.
    It sucks to get old
    Williamstown PA
    5,825
    no an aluminum one. I drill new holes from what i had a 200x and put on my raptor 660 which uses came hub as banshee.
