Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 81
Thread: ‘82 250R-put away wet
    Connecticut
    1,605
    The seat pan cleaned up nice. Did you use just vinegar or another rust removal product? Thanks for sharing your build.
    Aug 2015
    Idaho
    826
    Thanks for the tip on partzilla. That is much easier and really helpful. Which led me to search for the seat foam.
    http://hi-flite-usa.com/product/hond...ver-kit-e163k/
    Might just get a new for the price.
    Apr 2012
    USA
    4,133
    Yea kind of hard to beat that when used seats go for that kind of price on ebay.
    Aug 2015
    Idaho
    826
    Quote Originally Posted by sledcrazyinCT View Post
    You bet, sled—my pleasure. Or embarrassment.
    Yes, just apple cider vinegar.
    Aug 2015
    Idaho
    826
    I’ve received the pipe, head and cylinder:
    I’d like to blast and paint the cylinder. Can I use sand or glass? Tape off all the gasket areas really good? I’ve never done it, so any suggestions would be helpful.
    As far as painting, is it safe to have them powdered?
    Slidell, LA
    4,738
    Buy some gorilla tape and tape off all the machines surfaces and don’t be shy with the tape. Make sure it adequately covers and stick to all areas. You don’t want to inadvertently blast your new cylinder. I would use glass bead to blast and yes, powder is perfectly fine to use.
    Aug 2015
    Idaho
    826
    Thanks, that’s working out sweet. I think...got a tiny bit of glass through the tape. I thought I taped it well enough but apparently not. Hopefully it’s ok. I blew it out real good.
    To remove those black rubbers on the head, I was going to heat them up. Sounds good? I actually need a few more. Anyone know their purpose? Keep the integrity of the fins? Maybe their not crucial and I can stop looking.
    Got the bearings and just realized I need seals. Next time a get 2-days off, I’ll open it up. Thanks again.
    Slidell, LA
    4,738
    Those rubber bits are just wedged in there. You should be able to pull them out with some needle nose, but heat may help that process. Their purpose is what you said, keep the integrity of the fins and vibration dampening. Put them back in when you are done powdering.
    6,790
    All correct and I will add that they are for noise as well . The vibration noise without them is horrible .
    Aug 2015
    Idaho
    826
    Would you know where I could find some? I’d need 4 each of these:
    I checked eBay-that’s not going to happen. 25$ plus shipping for 3-pieces and one is literally in 3-pieces. Maybe I could cut them out of thick rubber.
    Edit: changed 2 to 4
    6,790
    I may have some , I can check this weekend .
    Aug 2015
    Idaho
    826
    Whoa, that would be fabulous. Thanks so much!
    Aug 2015
    Idaho
    826
    I edited the quantity before your post. Not being greedy. Thanks again
    Aug 2015
    Idaho
    826
    Crank checked out to be true and within spec. Click image for larger version.
    Is the kicker return spring normally at an angle? I didn’t get a picture before it separated on me. I think it hooks on the dowel pin but not sure. I can’t tell from the manual picture. Anyway, I tried a test fit and it appears to be really close to the other side case. There is a tiny mark on that side where it possibly touched the side of case, so I’m thinking that is the normal position it sits but thought I’d ask. Click image for larger version.
  15. #30
    Aug 2015
    Idaho
    826
    Got that back in.
    I’m putting the top end together, tonight and realized one of the head bolts are bent. When it went to get bored, they asked if It had been dropped upon disassembly because the cast in sleeve was ready to fall off. So it was re-sleeved. Now I need at a new bolt.
    Also, the wrong seat was delivered, today. Looks like it’s for a 2nd or 3rd gen. Other than that, I’m lovin’ this baby!! Oh, got my tires mounted last night on some fresh gold!!
    Judgment day is right around the corner.
