Thread: Pulse generator
    Oct 2018
    Ohio
    Pulse generator
    Hey guys new to the forum, I recently bought a 1984 atc 200s. An I noticed that the base of the pulse generator has a broke off bolt in it. My question is if I buy another pulse generator base an take the old off will I throw anything out of time? or have to watch what I do taking it apart an putting it together? Thanks
    Jul 2018
    TN
    1,065
    Setting the timing ain't hard. It can get aggravating sometimes because you have to stop, open the cover, adjust, reassemble ....repeat.
    BUT, it ain't hard.
    Use a white grease pencil to color in the 'T' on the flywheel. Makes it show up much better if you have shet eyes like me.
    I hook my timing light up to an old car battery and clip to the plug wire. Works great on my 200s.
    Once you get the timing right, don't forget to go back and set the gap between the rotor and pick up.
    Oct 2018
    Ohio
    The spark advancer should be the only thing I have to take off to get that base off right? If I put it back on same way it came off would it be ok?
    Sep 2018
    Ga
    46
    I would suggest getting a service manual if you haven't already. There are some decent videos on the pulse generator and setting the timing. Like Gabriel said, It ain't hard at all to set. D Ray's Shop on you tube has a multi part series about a 1985 atc200s that helped me a lot. Check it out https://www.youtube.com/watch?v=3-FFWrrzoN0
