It's somewhat time consuming thing. I could get it down in under 2hrs but I know how to.
You need to loosen the timing chain, unbolt the cam sprocket, slide if it off the cam and take the chain off. You might have to remove the cam for you to get the whole head off. Just get like 2 screw drivers and compress the valve springs and cam should come out. And remove the 4 head bolts.
1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
1984 Honda 110 ATC, orignal blue plastics,
1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
Honda US90 ATC, Collecting Dust
2004 TRX450R
