A question about running modern gasoline in the 84 200X and 250R. These 1984 200X engines were designed to run the old "SUPER" leaded fuel [see below for explanation of "super"], at least the Australian versions of the 200X were. So, Will i need to run a lead substitute additive in the fuel, as our petrol is now ALL unleaded fuel? I remember that using unleaded fuel in a leaded petrol engine, could cause the valve seats to "burn out" and a lead sub additive was required to be used. I assume this is only an issue in the 4 stroke engines, for obvious reasons but is it also a concern with the 2 strokes. I'm curious if this is an issue with modern unleaded fuels in the old trike motors and any info would be helpful.
Some history of fuel types in Australia:- We use the RON octane rating system over here, and USA uses the AKI octane rating [correct me if im wrong]. AKI ratings [87, 89, 91] are lower than our RON ratings [currently 91, 95, 98].
In 1984 most petrol engines here, were designed to run the old leaded fuel [which was called "SUPER" in Australia at that time, rated RON 94 to 97 octane depending on the manufacturer. "STANDARD" was also used less commonly, and rated at 87 - 91 RON]. This was the standard here until 1986 when all vehicles made after that year, were required to be run on unleaded fuel, but lead replacement petrol was available for old vehicles, though it was phased out and became illegal in around 2001, so all fuel is now unleaded.
I always used SUPER in my 200X, so i assume i will need to use our 95 or 98 RON unleaded nowadays to match the old octane rating, as it is never a good idea to run lower than specified octane rating in any engine and probably need a lead sub additive also.
Heres a link that explains octane rating very well, and the hazards of using lower than spec rating, for anyone interested
https://www.youtube.com/watch?v=La2Rt-_FL8E
I wonder how long they worked with oil passing through them?
