Results 1 to 15 of 16
Thread: Tri z domes, and porting,help advise .PLEASE
    Oct 2005
    uk
    87
    Finally tracked some domes down.
    Few questions for ya.
    Going for rebore and new piston .What make piston works better( dome of piston if there is any differences )
    Going to be ported with extra boost. Does anyone on here know somewhere in uk that knows what there doing .
    Has anyone got any pics of where to weld to save it from cracking
    Thanks ian
    3Z with Fangs! is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2018
    Virginia
    184
    Ian, I don't know that it has to be welded, the biggest issue is making sure mounts are tight so the engine can't move. That's what causes the cracks. I have pics of mine I'll try to post later.
    Mexico
    9,018
    I’m not convinced the weld is needed on every cylinder, but not all of them were created equally, so it’s a good idea to have it done.
    Just look at the left side of the cylinder and you’ll see that it has additional material next to the boost port, that’s what you want to duplicate on the right hand side.
    As far as I know all the piston domes out there have the same shape. Most people will tell you to stick with a Wiseco piston.
    For porting you’ll want to avoid anyone claiming they have some radical method of getting 60 hp out of your engine. There’s plenty to be gained from that engine with the boost port, some cleanup and matching of the transfers and raising the exhaust port a bit.
    It sucks to get old
    May 2018
    Virginia
    184
ID:	255412Click image for larger version.
ID:	255413 mine that I did
    Arizona
    843
    I just replaced my Tri-Z piston with a YZ 250 piston (83-87). They are basically identical except the YZ has a taller dome, whereas the Tri-Z is almost flat. If you are looking to bump up your compression a bit it's a good option. It will change your squish tolerance so you want to pay attention to that. When I first put the YZ piston in I had a problem with detonation because it reduced my squish to about .030 (I run 50/50 race and pump). I spaced it out to .042 with a copper base gasket and it fixed the problem. By the way, I found a great source for copper base gaskets for the Z. Copper Gaskets Unlimited makes gaskets in a wide variety of thicknesses so it makes it easier to hit your target squish tolerance. Here's a link to their website and a picture of their gasket.
    https://coppergaskets.us/
    Mexico
    9,018
    Quote Originally Posted by christph View Post
    Great to know on those gaskets, I need to check that out. I have a YZ piston that I’m going to compare to the Tri-Z piston, the only difference I remember is that there are windows in the three wheeler piston and none in the motorcycle piston.
    It sucks to get old
    Arizona
    843
    Yeah, the windows are different. Well, technically the YZ doesn't have windows. It has an arch-shaped cut out on the skirt. And the dome is definitely taller.
    Mexico
    9,018
    Ok, so I pulled them out and put them side by side. The YZ piston is about 1/2 mm taller, but it also has more meat on the dome. Definitely going to yield higher cylinder pressure.
    It seems the YZ has it’s own piston and the Tri Z and IT shared one.
    It sucks to get old
    May 2018
    Virginia
    184
    So the YZ Piston could be used with no issue to bump compression with basically no ill side effect?
    Mexico
    9,018
    Quote Originally Posted by 3Z with Fangs! View Post
    I’ve read yes and no and a bunch of other theories about which is best and why. Search this site and you’ll find some.
    Myself I would think the difference might have something to do with the larger intake of the YZ. I guess you could put windows in the YZ piston too.
    Maybe the single boyseen port on the Tri-Z necessitated the windows rather than the cutout of the YZ piston? Someone smarter than me must know, like maybe a Yamaha engineer
    Does anyone have an IT cylinder? Guessing it’s a hybrid of the YZ and Tri-Z cylinders.
    It sucks to get old
    Oct 2005
    uk
    87
    I was thinking the yz piston and head,if i cant get the domes, also they do a 70mm piston with a pretty flat dome,needs a resleev though.Im only looking for different options until i get the lump out.
    May 2018
    Virginia
    184
    Water outlets on the YZ head are configured differently. I guess you can fanagle something but the hoses won't be direct line with the TRI-Z head.
    Mexico
    9,018
    I belive you need the YZ cylinder to use the YZ head. That implies a power valve, rad hoses and having the carb in a different place. The last good thread I saw on this was Neverlift's build if you want to look it up.
    It sucks to get old
    Mexico
    9,018
    Are you using that cylinder? It looks like your sleeve is broken.
    It sucks to get old
    May 2018
    Virginia
    184
    no, I got another jug and started over. This cylinder awaits a bigger sleeve.
