Results 1 to 15 of 15
Thread: 200e recoil pulley-powder coat?? Ok idea??
    Aug 2015
    Idaho
    840
    Went to replace my broken rope. Couldn’t wrap it around the rust, so.....apple cider vinegar removed most of it. Blasted it for good measure.
    I’m thinking of having it powdered, just to slow the growth of future rust.
    Also, no more gaskets for this-that I can find.
    TTown, Alabama, United States
    845
    I had a starter that ate rope like crazy and it took a lot longer than it should have to figure out that the rust on the pulley and in the eye of the starter was causing it. i just sanded it down with scotchbrite and its been fine for years. Now that its been blasted it would probably rust back faster if you don't paint it or powder coat it.
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    When the going gets tough, the tough get sideways
    Aug 2015
    Idaho
    840
    Lol, yes most definitely would rust faster, now. The cider striped the anodized coating and I was thinking powder coated would be fine. But then again, I’ve never done this. Thanks for the reply. It’s bagged and ready to be dropped off today. Whether it be a plater or a coater-powder will be a faster turn around for me. I was just hoping the ‘dogs’ will still fit if I have it powdered.
    Edit: I should have put powder coat VS anodizing in the title-my mistake.
    Jul 2018
    TN
    1,065
    Isn't that part steel? If so, you won't be anodizing it. Powder coat, yes. Anodizing is an oxide of sorts. Iron oxide is what you're trying to defeat here. LOL.
    Might ask for it to be chrome plated. The plating will be thinner than PC and less likely to cause problems with mating parts.
    If it were me, I'd use a good quality engine enamel, paint it and make sure it's thoroughly cured before assembly.
    6,808
    Factory finish is zink plating , powder is thick and will ruin the pulley . A good coat of galvanized spray paint and grease on all the moving parts is all you need . Check the dawg area for cracks . The factory handle is still available new and that will keep the water out and if you can’t find a gasket just seal it with rtv .
    Aug 2015
    Idaho
    840
    Factory finish is zink plating , powder is thick and will ruin the pully . A good coat of galvanized spray paint and grease on all the moving parts is all you need . Check the dawg area for cracks . The factory handle is still available new and that will keep the water out and if you can’t find a gasket just seal it with rtv .
    Ah, zink. well...I’m glad I asked. Thank you guys!! I’ll get some paint.
    N/A
    5,818
    just have it powder coated. thicker stronger lasts
    Aug 2015
    Idaho
    840
    Is this what you’re referring to:
    If so, I’ve got some already. Thanks
    Aug 2015
    Idaho
    840
    I’ve gathered you like pc. Me too! The thickness had me wondering on this application, though.
    6,808
    Yes good stuff
    Quote Originally Posted by Jd110 View Post
    6,808
    Right lol , can’t imagin if you powder coated the dawg cavity’s , they would never fit again
    N/A
    5,818
    powder is not to be applied very thick, some people do but you don't need much. I've seen it crazy thick or very light, depends who has been educated who is applying it.
    Aug 2015
    Idaho
    840
    Painting it works fine. Thanks for the advice!
    Before:
    Aug 2015
    Idaho
    840
    I went ahead and had my spare powered for a whopping $5.
    I was initially wondering if the dawgs would fit in their cavities and found it works perfectly if the powder coating isn’t too thick.
    Just so ANYONE knows, often things like brake pivots are very worn out, and if I powder them, that takes up the slack...
    Just need to be aware that powder can add .005 or 5 thousandths depending on the powder amount applied. It can be very helpful...
