Thread: 90/110 oil cooler
    Nov 2015
    Davenport iowa
    1,144
    90/110 oil cooler
    I was wondering what you 90/110 guys are running for a oil cooler and if you think it helps. I'm talking modified motors here 130 cc and up
    1974 original 90 X 2
    1974 Original 70.
ID:	255517 This is what I've been using on my flat track 70's. It does help cause you could feel the difference in the oil lines.
    Feb 2013
    Brazil, Indiana
    728
    Quote Originally Posted by DAM shop View Post
    Once you find a cooler I've posted the installation instructions here on the forum for 2 different brands of oil coolers. It shows where to drill, tap and plug the oil galleys on 90/110 and 185/200 engines.
    Sent from my SM-G965U using Tapatalk
    1979 ATC110
    1983 ATC110
    1984 ATC110
    1984 ATC125M
    1985 ATC110 2 of them
    1985 ATC110 The wife's
    1987 ATC125M
    1985 ATC250ES
    1984 DX225 with 250 timberwolf engine and swingarm. Wolf in DX clothing
    May 2013
    Brownsville, Tn.
    1,271
    Two different schools of thought.
    First is probably the best but not the easiest. It's called an Oil Bypass System. On the 90/110 where you pick up the most heat as well as experience the highest chance of engine failure is oil going or not going through the oil passage up the cylinder into the head.
    The first example pulls the oil out of the oil pump and takes it directly to the head. Almost eliminating having to have an inline cooler.
    Second example comes out of the side of the cylinder and goes directly to the head. Just another way to do it. Maybe a little easier than the first.
    And finally and probably the most common because it is the easiest. This uses an aftermarket piece but you can use a modified stock cam cover.
    * Nicholson 500 Race Bike *
    Do the 110's have a restrictor in the block like the 70's to lower the oil flow to the head?
