Results 1 to 8 of 8
Thread: 1984 200x cam swap
    Jul 2018
    St. Clair Shores, MI Grayling, MI
    67
    1984 200x cam swap
    I just got a 200x and was wondering about a cam swap to wake up the motor slightly. I've read quite a few different cam choices that work well. My question is about the actual swap. Can this be performed without removing the motor? I'm new to these machines so I beg you pardon if this is a silly question. Don't seem to be finding anything when I search.
    Thanks!
    '84 Honda 200x ATC
    '84 Honda 200m ATC
    '85 Honda 200s ATC
    '85 Honda 125m ATC
    Slidell, LA
    4,738
    Yes, you can remove the rocker cover for the cam swap while in the frame. I would get the Webcamshafts 389a with upgraded springs and retainers.
    Jul 2018
    67
    Thank you. Appreciate the response. What kind of response does the 389a cam give?
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    '84 Honda 200x ATC
    '84 Honda 200m ATC
    '85 Honda 200s ATC
    '85 Honda 125m ATC
    Slidell, LA
    4,738
    Mid to upper response.
    Jul 2018
    67
    Sounds good, thanks!
    '84 Honda 200x ATC
    '84 Honda 200m ATC
    '85 Honda 200s ATC
    '85 Honda 125m ATC
    Leevvii's Avatar
    Leevvii is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2016
    Australia
    216
    Some XR 200 cams will fit the 200x, I think they improve midrange, probably not as sporty as the 389a cam, but still an option
    n
    6,809
    If your going with a cam that requires heavy duty springs then yes you will need to remove the motor . The cylinder head will not come off without removing the motor .
    If your going with a cam that doesn’t require HD springs then all you need to do is pull the pulser/ CDI cover and the cam will come out , get a manual for the steps on how to .
    Jul 2018
    67
    Thanks. Sounds like I'm gonna wait and rebuild the entire motor when the time comes. Appreciate the input!
    '84 Honda 200x ATC
    '84 Honda 200m ATC
    '85 Honda 200s ATC
    '85 Honda 125m ATC
