I have a 1986 Honda 350x that I’m having clutch problems with. When trying to pull start it ,It will go into neutral but when you try to disengage the clutch there is no gears.
Welcome to the site.
You are going to have to give us more details on what is going on. Guessing the kicker does not work to start it??
'83 200X
Yes it works. When I got it they said it was stuck in gear, but it doesn’t go into any gears, it’s like it’s stuck in neutral.
If the kick start works. Why are you trying to pull start it(?) I am sure "They" more know about a problem. I am sure you are into a deeper problem by the sounds of it.
'83 200X
Sounds like more than a clutch problem. Does it run?
