Thread: Bulb Identification?
    Jul 2018
    TN
    1,065
    Is there a reference online somewhere that'll let me determine what bulb I have in my hand? I tried googling the part number but all I get is crap.
    I have a couple boxes of brand new bulbs and no idea what they are.
    Here's a list. If anyone knows what they are, please let me know. Thanks!!
    SPI L62605A I have 8 of these.
    A7028 I have 4
    LB457 I have 2
    HL114 I have 2
    11-2144 I have 1
    I also have a box with 9 new bulbs marked: 6v Suzuki 09471-06015
    Thanks fellas!!!
    Apr 2012
    USA
    4,133
    Post photos and I'd probably be able to ID some of them. I don't know them by part number, also need wattage and voltage specs, should be on the bulb somewhere. Like 36.5/35w 12v is a stock 350x headlight's specs, but the bulb type/shape determines socket fitment.
    Everything I know on the bulbs would be in the context of Honda. I'd need two photos per bulb (or maybe one if you get a good angle). Need to see overall bulb shape, and the connector side for the contacts.
    Jul 2018
    TN
    1,065
    Ok Fixer. You asked for it.
    Solero Halogen H4 12v 60/55w
    Philips Halotone Aluminum reflector 12v 20w 409355
    SPI 6v 3w Honda number in the pic
    Candlepower 12v/1CP
    Jul 2018
    TN
    1,065
    6v Suzuki 6v 25/25w
    SPI L62605A 12v 60/60w
    A7028 12v 45/45w
    Apr 2012
    USA
    4,133
    Quote Originally Posted by Gabriel View Post
    Ahh my internet you knew my weakness lol.
    Common headlight in the atv world, H4 is a pretty common name they go by in the automotive world, but the base style is called a P43T. This would be for like an ATC250R 200X 250ES 250SX (all from memory, wattage might differ though). Below is the Honda part number.
    https://www.partzilla.com/product/ho...e0e3d2af547ee3
    No clue on this one, the base style looks like a typical automotive brake light bulb, can't remember their number off hand, but it has a running light pin and a bright/brake light pin, outer section is the ground.
    Yea this one pretty much explains it's self. The base type matches a ton of atv's, but most are 12v 5w to 10w. First machine I thought of was the ATC110, early models were 6V. Here's it's part number, same specs and pretty sure the base type is the same, so it's a second Honda part number to reference, page of course has the interchange too.
    https://www.partzilla.com/product/ho...67268a39639ada
    Here's the part number on the box (both pages probably get you the same part in the mail)
    https://www.partzilla.com/product/ho...=34902-202-000
    Candlepower 12v/1CP
    Pretty sure they are the same thing as the bulb above it, they atleast look the same size in the photos. Of course these are 12v, so it would be for machines with 12v systems. No wattage spec, so not sure what exactly it would fit, but like a 350x uses a 5w, and I think around an 86 200x they use 8w or 10w.
    6v Suzuki 6v 25/25w
    Headlight bulb, since I know Honda's best and the Suzuki part number is there already, here's a Honda part number it should interchange to. The fitment list is so long it cuts of a lot of machines. I based it on the ATC90 first (it uses 15w/15w though), then looked up early ATC110 and it's a spot on match. Maybe another site has a better interchange list since partzilla broke their great system something like a year ago.
    https://www.partzilla.com/product/ho...fcef898bfe571b
    Basically the same thing as the 55/60w, just dim's consumes 60w as well. I've seen some Honda's use this bulb, but I can't seem to dig one up, either it's the uncommon/expensive 45/45w, or the 55/60w ones. Really these should work just fine to replace a 55/60w bulb.
    A7028 12v 45/45w
    This is the opposite type of bulb base than the 350x uses. It twists into the socket. I ran across a million machines using these when I was researching for atc350x sockets. Here's a honda part number that's the same base type, but the glass bulb shape is larger. The smaller ones should fit these applications though. I can't seem to find an exact match, all the ones that are the same style are lower wattage, highest being 40/40W for a Rincon. I used to know what the base was called, but it escapes me now, I did the research like 5 years ago lol.
    https://www.partzilla.com/product/ho...6c9919d677282a
    Hopefully that helps. I know the 350x style bulbs in the automotive world (well motorocycle) are called a HM202.
