Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: MISC Part Measurements
    Apr 2012
    USA
    4,133
    Yea this thread isn't meant to be the place to search for data, it's more of a data caching location so it can be collected and compiled into something a lot easier to use later on. It's public info, so really anyone could use it. I suspect if enough info is on this thread, google might hit it fairly well if the right keywords are used. That's also why I put the machine info etc per post to help those from google results follow what the data is/means.
    I've been playing around with data, databases etc for quite a while now. Last job was a Database Administrator, so kind of part of the job title =).
    Apr 2012
    USA
    4,133
    1985 Tri-Z Rear Hubs
    Part number: 2XJ-25383-50-00
    Part number Interchange:
    • 1985-1986 Tri-Z YTZ250
    • 1988-2006 Blaster YFS200
    Bolt pattern: 4x100mm
    Spine size: 25mm
    Hub thickness (where it interfaces with the splines on the axle): 43mm
    Offset: 8mm from axle bolt surface (inaccurate measurement with caliper + eyeballing)
    Photos kind of unrelated, but they fit on 84 TRX200 and ATC200ES axles.
    Attached Thumbnails Attached Thumbnails IMG_20190615_121748_617.jpg   IMG_20190615_121804_351.jpg   IMG_20190615_121849_112.jpg
