Results 1 to 10 of 10
Thread: noob question what is the nut called that adjusts the chain on a 1985 atc 350x
    Dec 2018
    fayetville nc
    35
    what is the nut called that tightens your chain on a 1985 atc350x bearing carrier
    Aug 2016
    East of Worcester ma
    1,353
    Um, hmmm- like what my finger is pointing at? It’s part of the bearing carrier itself.
    (Not a 350x swingarm) but there very similar in style.
    Shep
    Dec 2018
    fayetville nc
    35
    yes what is that called
    Aug 2016
    1,353
    Quote Originally Posted by jrock454 View Post
    Really???
    Ps- “bearing carrier”
    Dec 2018
    fayetville nc
    35
    have you ever seen a 85 350x
    Dec 2018
    fayetville nc
    35
    where you put the wrench to tighten the chain is broke halfway would i have to buy a new bearing carrier
    Aug 2016
    1,353
    Yup- doesn’t it have 5 wheels? Or 6
    If u don’t like my answer, that’s ok- I really don’t have the patience to argue w/you at the moment.
    Shep
    Dec 2018
    fayetville nc
    35
    hey i wasnt arguing with you i was asking have you ever seen a 1985 350x because the 86 uses the pry method it has holes in it and the 85 uses the wrench method sorry for the confussion
    Aug 2016
    1,353
    The carrier is a one piece cast part- just be sure to get the correct yr for a replacement, there’s aftermarket ones I’ve seen but you’ll need to investigate if there’s any better/worse brands to buy.
    It’s just been a long couple days/ I probably shouldn’t have responded at all.
    There’s a good group of guys here-really
    Shep
    Ranvier is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2016
    Phoenix, AZ
    307
    I own both and use a brass punch and some gentle tapping on both.
