Thread: Has anyone found a way to custom make carb to airbox rubber boots?
    Jun 2017
    Atlanta
    111
    Has anyone found a way to make a custom carb to airbox rubber boot for '83 Honda 200E or '81 Honda 200? The ones on Ebay look old, rotten, and expensive. I would assume a 27mm hose of some sort could be made to work, but where would you find one? Home improvement store, auto part store. Hoping someone has already went through this and has the answers! I couldn't find a thread for these 2 trikes already created.
    Williamstown PA
    5,825
    design it as one peice made of aluminum weld it up. end of story.
    Jun 2017
    Atlanta
    111
    Great idea, it never crossed my mind to use metal. Maybe sheet metal thin enough to bend into a cylinder. I don't have a welder but will need to think of another way!
    Gripit'n'ripit's Avatar
    Gripit'n'ripit is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    Rochester NY
    251
    I made my own a few years back ,using the original OEM boot as a template. Used Gas fill hose and clamps. I haven't had any problems with it.
    The hose is flexible enough that I use carburetors 28mm-36mm and it is a quick swap, though the 36mm can be a bear to slip in.
    It worked well will plain steel, the one shown is stainless.
    Disclaimer: friend welded the stainless.
    Here is the thread
    http://www.3wheelerworld.com/showthr...advice-welcome
Name:	Boot comparison small.jpg
ID:	256620Click image for larger version.
Name:	Stainless boot small.jpg
ID:	256621 Click image for larger version.
Name:	Installed boot left small.jpg
    81 250R Custom
    83 250R (in progress)
    98 Scrambler 400
    03 Bombardier Quest 500
    07 Polaris Predator (sold to klondike1020 )
    68 VW Dune Buggy
    Apr 2012
    USA
    4,129
    I think OP is talking about the other side, carb to air box interface.
    Pretty sure they are just rubber, someone that knows how to mold plastics (pour molding) should be able to make one with an oem one to use as a template. Just would have to pick the right grade of mix to be gas safe and such, and also be flexible so installing the carb and such is easy.
    Another option, depending on your riding conditions is to just pull the airbox completely out and run a clamp on air filter directly on the carb.
