Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: 200x Build Performance Carb Question
    I bet you will NEVER EVER EVER again put a motor back together without perfect kicker parts will you??
    Glad your all set!
    Nov 2018
    NC
    87
    Quote Originally Posted by ZachH View Post
    Thanks! Might be the way to go. Ill let you know if I try it out.
    Yes definately let me know if you try it, I have been trying to decide if I was gonna go with the 28 mikuni, and I have a clamp on filter I can use its a uni with precharger. However I have not given up on the factory one just yet....but that may change.
    Nov 2018
    NC
    87
    Glad your all set!
    I would not, thats why I dropped $100 for an oem bnib set for mine. The others were missing a bit on the 10.25 to 1, so I knew 12.1 to 1 would be way worse. Didn't want to take a chance.
    Think the only one I have had that was worse was my 2003 raptor 660. It had electric but it had 6 or 8 socket head bolts that secured the starter gear to the one way bearing. It had a bad habit of shearing them off, and dropping the heads in the bottom of the motor. Replaced with the strongest I could get from fastenal, lasted way longer than stock, but over time the compression would snap them too. I do not miss that but still miss the bike, it was quick with the ct racing mods I had on it.
    Apr 2017
    Ohio
    51
    Hey shortline, sorry to open an old thread but I have gotten my x up and running and am ready for a carb, will the flat slide mikuni fit in the frame without mods?
    "I'm Watchin' The Herk N' Jerk!"
    3&2moto on YouTube
    Trikefest 10,17,18,19
    6,783
    Yes it fits but you need the short intake manifold , if you use the longer version then the frame needs dented in a little and possibly one of the over flow / vent tubes on the carburetor trimmed .
    Apr 2017
    Ohio
    51
    Any idea where to look?
    Your kicker gears fixed me right up by the way! Thanks again for that!
    3&2moto on YouTube
    6,783
    Manifolds are hard to come by , possibly place a wanted ad here and keep an eye on eBay or make one .
