Page 5 of 16 FirstFirst ... 3 4 5 6 7 15 ... LastLast
Results 61 to 75 of 228
Thread: Barnboy's 1984 ATC200M Rebuild
  1. #61
    The Open Road
    4,736
    Motor looks fantastic
    So does that NASA axle.... WOW
    Sucks about the frame. I'm hoping you can save it
  2. #62
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    732
    I mostly say that for people wanting to flip these things, but in your case...wowzers, good luck with that one. I'll definitely appreciate seeing what your solution is.
    I understand the amount of work that goes into something like that.
    Keeping the foot peg area clean is a real PITA though. It's a big muck trap. I'm surprise more of them aren't rusted out in that area.
    Yeah I totally understand. And honestly....I think you are correct, I was just talking a lil smack. But I'm gonna give this a go. However I'm open to the fact that it may not be fixable. For example if we cut into it and its rotten way further than we thought, and so much would have to be cut out that its new frame time. Whether that be custom or a solid OEM. If I had the resources I would be building a custom full suspension frame, cause that would be badazz. But I'd like to at least attempt to repair this one. Whats the worst I can do? Screw it up worse??
    You are absolutely correct re: keeping the footpeg cavity clean. I would wager that if everyone that owned a hardtail that was taken through mud etc often checked that area, 75% would have rust. At least. I will likely drill some larger drain holes in the tube, and also some drain holes in the footpeg mounting crossmember. Also will be going around and welding places like the end of the flattened frame tubes, where water can get in. Plus, instead if the paper-thin tube honda used, ill be replacing the rusted section with 1" OD DOM. Likely .109 or .125 wall....but .125 wall may be too thick. We shall see.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
  3. #63
    Jun 2015
    Oklahoma
    732
    Thanks Chop, appreciate it. That NASA axle was def a cool piece to score. Beats a used replated OEM axle all to pieces.
    Will keep this thread updated with pics of progress on the frame.
    Da velder
    Feedback:
  4. #64
    Jun 2015
    Oklahoma
    732
    Aaaaaaand we are moving forward. Parts cut on the plaz today. Need to get some tube and then start makin sparks!!
ID:	264270Click image for larger version.
    Da velder
    Feedback:
  5. #65
    Jun 2015
    Oklahoma
    732
    Update!!! Stuffs been happening on the build, some good some bad. Let's start with the good. Frame subsection is fabbed up and welded out! Looks good as new and definitely more heavy duty, which is perfect I used 1" OD 0.125" wall DOM tubing, bent on the JD2 bender. I also turned 2 plugs to fit inside the old frame tube and the new stock, to keep things lined up. Then the whole thing was TIG welded, my first time ever TIG welding carbon, prior to this I've touched a TIG torch maybe 2x really, just on some aluminum here and there.
    I also drilled some 5/16" drain holes in the bottom of the frame tube, along with 2 new holes on the bottom of the footpeg mount/dirt collector.
ID:	264814Click image for larger version.
    Note the 2 extra holes
    Da velder
    Feedback:
  6. #66
    Arkansas
    2,447
    The Six Million Dollar Trike
    You sir, have got to be in the top tier of hardtail frame savers. Right tools, right experience, right on time.
  7. #67
    Jun 2015
    Oklahoma
    732
    Yeah no kidding. Haha, I'm going to have 10x into it what its worth, but thats ok with me. Its never gonna be sold.
    Thanks King, its honestly just access to the right tools and at the right time. I work in a weld shop as a fabricator by day, but we really don't do any tube work or TIG welding. That part is new to me, learning as I go.
    But it gets better, I still have that back section to cut out and re-gusset. Should be a piece of cake though, compared to the bending and coping of that compound angle of the motor cradle.
    Da velder
    Feedback:
  8. #68
    Jun 2015
    Oklahoma
    732
    Finally got my frame finished folks! That was a bunch of welding, cutting, and fabricating but its done.
    Made some skid plate mounting blocks
    And built up the worn steering stop
    Da velder
    Feedback:
  9. #69
    Jun 2015
    Oklahoma
    732
    So, as some of you may have seen in my other thread...my motor paint turned out a flop. Looked great till I pulled the masking tape and half of it flaked off. Multiple issues, probably including operator error contributed to this issue. My plan is to turn some plugs on the lathe and use a hot pressure washer to remove the paint, then prep and repaint again.
    Da velder
    Feedback:
  10. #70
    Jun 2015
    Oklahoma
    732
    I've been pondering the best way to modify my rear bearing carrier to convert it to disc brakes. My solution is to build a completely new one from scratch. I will R&D (rip off and duplicate) the mounting brackets in CAD and cut them on the CNC plasma table, turn my own custom housing and design and plasma cut a mounting bracket for whatever caliper I end up using. Should be less time and look wayyy cleaner than modifying the old housing. Stay tuned.....
    Da velder
    Feedback:
  11. #71
    az
    2,025
    that's a chain drive right? easy idea i have is to just use the original drum as a hub to mount a disc on. might need a 1/8 inch or 1/4 inch washer to move the disc out. bolt the disc to the brake hub and build a mount for a caliper. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
  12. #72
    Apr 2014
    Edmond, KS
    2,591
    Maybe you could find a wrecked, chain drive quad with disc brakes for cheap. Then cut the carriers off and weld the quad carrier onto your trike and use the rest of the quad parts as well. I'm NOT talking about the cheap, Chinese quads.
  13. #73
    Jun 2015
    Oklahoma
    732
    Yes, its chain driven. A 200X rear rotor and hub fits the axle, same spline. Thats what ill be using, just have to make a small spacer to make up for the narrower width vs the drum. The caliper used will be a XR650 front caliper dual piston, cause I can. And that's what I have available.
    I could use another carrier, or mount it to the existing housing somehow, but wheres the fun in that. Thats not how I roll, I'm going to build one better than you could ever hack together from stock parts. And it won't take much more time either compared to modding an existing one. Also, doing it the way I'm thinking, I can incorporate a small lift and stretch directly into the carrier mounts, like a true bolt on lift kit, no welding necessary. Whether I do that or not remains to be seen, we'll see what I come up with first.
    Da velder
    Feedback:
  14. #74
    The Open Road
    4,736
    This thread is awesome
    Nice work on the frame, sir!
  15. #75
    You're lucky that the 200X splines are the same. When I made my ATC70 disc setup I just mounted a ATC70 drum in my lathe and turned it all off aside from the splines and made a shoulder on the hub. I welded on a flange and turned it straight in the lathe and found that an 82 250R disc was the perfect size.
    I had some kind of NOS japanese caliper laying around and used that. If there's a will there's a way...
    There's a dude on Facebook selling ATC 70 disc brake kits and he is charging almost 300$ and uses China brake parts
