Yeah, this is coming along sweet! Wish I had access to a lathe and plasma goodies.
1980 Honda 110-125 lifan manual clutch *in progress*
1985 200x - building peice by piece
1981 HONDA ATC185S - parts
Da velder
Feedback:
Had some time last night to get some more work done. I got the bracket welded on within 0.020" square and warpage after welding. Probably not too bad considering the heat that went into it. Not super happy with my TIG welds but they cleaned up ok. Still learning as I go.
Needed a flat surface to measure from so I chucked this 6" slug in the lathe and faced off one side. Works much better than the bench which was all dirty and probably not flat from being dinged up.
Da velder
Feedback:
It's looking good.
Maybe after you get that one finished, you could bang out a few more to sell and see how it goes. A hydraulic, rear disk brake on those hardtails is a huge improvement, and I'm guessing that one carrier would fit several models, including the 200E.
Thought about it, we'll see how this one goes. The machining takes a fair bit of time and setup. The snow has been too deep on unplowed roads still to make it out to the shop and finish welding it. Hopefully soon...
Da velder
Feedback:
Very nice work
Da velder
Feedback:
Man that's too pretty to paint!
Awesome job
MrC.
mrc_builds on YouTube Channel
My Addiction
85 350x "The Nice One"
86 350x
85 350x "Yard Sale" Flat Tracker
84 250r "lucky"
85 250sx "Enterprise"
85 350x "Code Red"
86 250r "Unicorn"
86 trx250r
88 Lt250r Suzuki
83 Z50r
85 ATC 70
88 KD80x
85 CR250r
84 KXT250r Tecate
Nice. I just bought every 200X rear disk on hub on Ebay.
JK![]()
I am very impressed with your work. This is going to turn out awesome.
Ha I better snag some more up so I can offer a kit ATC King.
Thanks guys I appreciate the compliments. Hopefully I can design and cut the last bracket next week and get this thing done.
Da velder
Feedback:
Back from the dead! Finally got the last mount designed, all I need to do is cut some prototypes and start test fitting it. Was quite the reverse engineering project, thankful to have a friend skilled enough in CAD to help me along through the process. When it's done then it's time for powder and moving on with life!
Da velder
Feedback:
Got the carrier finished last night. This being the first prototype, I've learned along the way and it's been a bunch of trial and error. In the future when I make another one I plan to modify my CAD drawing to where the caliper bracket and frame mounting bracket are one piece. However I couldn't get those measurements as I was building from scratch, so this carrier uses the 2 brackets welded together. Welded directly to the mounting bracket, not the axle tube as it doesent take much to warp it and the bearings will not fit properly. If I did it again I would weld the brackets on, then chuck in the lathe and bore for the bearings. Then it will fit perfect, no distortion.
Da velder
Feedback:
Update: final got all my parts together for powdercoating. I
think. Found a place with good recommendation to PC my 250r frame, swinger, and hopefully 200M front triple for $175, as those are the only items that will not be coated black. Then the rest of the 200M stuff is gonna be PC'ed black, and should be able to get that done for under $300 I hope. Then I need to make one more plug for my 200M motor, powerwash, and repaint. I've got like 4 hrs a week to work on this project so I'm making progress, albeit slowly.
Da velder
Feedback:
